superboop
Wisconsin
Anyone know where the fuse panel is for the main fuses for the dash? I bought an original owner 47k mile Holiday Rambler Limited on a Gillig Chassis that came with all of the original books and wiring schematics but it doesn't seem to indicate where the fuse panel is located, just once you find it where the fuses are located.
jdc1
Rescue, Ca
Have you tried the Holiday Rambler forums?
Something I found (Different chassis, different body builder) is sometime the fuse charts are ignored by the body builder. The HEVAC system is not a "Chasis" item but a body builder item So on my rig there were 3 fuse boxes that applied to the "Vehicle" side of life (which includes the dash HEVAC) and sure enough one of the panels had fuse labeled "heater" or Air Conditioner (forget which)
That was not where the body builder hooked the lead (I eventually found out where and fixed the issue but it was not easy) Was not the only thing they screwed up.
Tool you can use is a TEST LIGHT.. this looks a bit like an old fashion ice pick (Works like one if you need an ice pick) but the handle is clear or translucent with a light builb inside and a wire with a clip lead.
For this test the test lamp beats the (Explative omitted) out of a multi meter for you test the fuses IN SOCKET and about one fuse every 2 seconds.
Clip the lead to a known good ground.
Most Vehicles these days use blade fuses. in each "End" of the fuse is a "Window" of sorts.
Now first touch the tip to a known battery source.. Bright good. often I have to re-seat the lamp.
Touch each window Ignition in a position that the blower should blow.
BRIGHT BRIGHT good fuse
DARK DARK no test this fuse does not have power (It's also not the fuse you want)
Bright Dark or Dark bright... DING DING DING you found it.
Argosy24
MI
I have a 93 Beaver on a Gillig chassis. The Gillig schematics show pretty much anything in the cockpit goes through circuit breakers. On mine they're just below the windshield under the 'hood' and in front of the driver in a black box. Not sure that will help but it's easy enough to take a quick look.
