shannon62
Pennsylvania
Hello All, I have a 2017 Ford Fusion SE with a 2.5L engine FWD & was wondering if anybody has towed one 4 wheels down & what did you need to do if anything to tow. Me & wife are getting older & do not like doing the dolly. As always thank you all in advance.
Cambria, California area
Does Ford say the 2017 Fusion SE can be towed four down? Remember, what does Ford says, not a friend.
wildtoad
Blythewood, SC
If you have the owners manual it should tell you if you can tow it 4 down and the steps to make it so.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Janss
Sedona, AZ
I just looked on Motorhome Magazine's 2017 Dinghy Towing Guide list and while the Fusion Hybrid and Fusion 2.7L AWD are listed as 4-down towable, your specific model is not listed.
But don't go by any list or what anyone says....You should absolutely look in your owners manual (as suggested above) under Recreational Towing or something like that (not Emergency Towing) to be sure.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
shannon62
Pennsylvania
Okay thanks for the info, i had called Ford Dealer & they said no to 4 wheels down, but i read online that you could add a lube pump to make
some cars 4 down. I was wondering if anyone has done this?
willald
NC
shannon62 wrote: Okay thanks for the info, i had called Ford Dealer & they said no to 4 wheels down, but i read online that you could add a lube pump to make
I did that years ago, on a Kia Sedona minivan. It worked OK, but I would not recommend such. Don't believe it matters, as I'm pretty sure I saw where the company that used to make the lube pumps for that purpose (Remco), quit making them some time ago. Soo, that is probably not an option, regardless.
Update: Yes, Remco indeed quit making them back in October 2020. Here is the announcement they gave about it.
Its too bad you didn't get the Hybrid Ford Fusion model. I had one of those for years, it was a blast to drive, and one of the easiest, best vehicles for flat towing I ever owned. If it hadn't been totaled in a wreck about 4 years ago, I'd probably still own it and be towing it.
edited 04/05/22 01:04pm by willald *
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
Janss
Sedona, AZ
I have friends who also did that years ago on a Toyota Matrix. They had nothing but problems.
shannon62
Pennsylvania
Well okay i guess the lube pump is out, well we love our Fusion, so for now we will dolly 2 wheels up. Thanks again for all the info.
Happy & Safe Travels
