RV.Net Open Roads Forum: truck camper sitting in a wet truck bed
 > truck camper sitting in a wet truck bed
gitpicker2009
texas
Posted: 04/03/22 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Just a maybe stupid question: My Arctic Fox 1150 sits on a rubber mat, maybe a half inch thick in the bed of my 4500 dually.
The bed has an industrial finish bed liner, so it's virtually water tight.
It does drain, but not always completely. Should I be worried about the truck camper bottom being slightly wet?
I often wonder while driving through heavy rains also.
I mean, it's not like it's sitting in 3 inches of water, but more about residual moisture and occasionally a maybe a 1/4 inch of water until it drains/dries.
Thanks for any and all advice.
zb39
slippery rock
Posted: 04/03/22 08:57am Link  |  Quote  |  Print  |  Notify Moderator
i dont think its a problem. it prob dries in 24 hours.
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
2022 Host Cascade
2021 Ram 5500 Air ride
Bedlam
PNW
Posted: 04/03/22 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Pickup beds have drains in the corners to prevent this. you may want to do the same in your sealed tub.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
Posted: 04/03/22 11:28am Link  |  Quote  |  Print  |  Notify Moderator
It’s only a problem if the water is deeper than your bed mat.
But I’d do Iike bedlam said and eliminate the issue completely.
2017 Heartland Torque T29
JimK-NY
NY
Posted: 04/03/22 11:45am Link  |  Quote  |  Print  |  Notify Moderator
My truck has a liner and drain holes in the front corners of the bed. Anyway, no water ever gets into this area. My camper overhangs the sides of the truck bed rails by several inches and the gap between the camper and rails is only a couple of inches.
I store extra boots, clothing and paper goods between the camper and the truck. No water or dampness ever in years of doing this.
mkirsch
Rochester, NY
Posted: 04/04/22 06:32am Link  |  Quote  |  Print  |  Notify Moderator
I would question why water is even getting in there in the first place with the camper in the bed. Even running in the heaviest rain my little Palomino keeps the bed covered and dry. Your big Arctic Fox is a bunch wider and longer.
You might have an internal tank leaking out into the bed.
notsobigjoe
southeast
Posted: 04/04/22 10:19am Link  |  Quote  |  Print  |  Notify Moderator
I Agree, This is what I was thinking. Mine sits in the bed almost year round in central Florida where it pretty much rains everyday and it's dry. It's dry going down the road as well as I driven through many a rain storms and took the camper off to a dry bed. Many members use the available space for storage under the wings because it's dry. Of course with all that said it could be different with other camper manufacturers. JMHO
Joe
Posted: 04/04/22 10:37am Link  |  Quote  |  Print  |  Notify Moderator
OP's truck is sitting on a dually flatbed. Different situation than a pickup bed.
Bottom line though, it's not really a question anyway. If it holds water, drill a couple holes in the appropriate spot.
If the bottom of the camper stays wet and continues to soak up moisture, it will rot. If it's above high water on the mat, then it's not a concern, however the OP has to decide that....but it's just too easy to put a couple drain holes in the bad and be done with it.
kohldad
Goose Creek, SC
Posted: 04/04/22 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
On both of my last two trucks, after the bed liner was sprayed in, I took a large screw driver in the drain slots and pried them open so they were larger. This allows the water to drain faster.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
mellow
Salisbury, MD
Posted: 04/05/22 08:29am Link  |  Quote  |  Print  |  Notify Moderator
You could always install a sump pump [emoticon]
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
