RV.Net Open Roads Forum: Fifth-Wheels: Slide design by Grand Design
 > Slide design by Grand Design
Page of 7
Lantley
Ellicott City, Maryland
Posted: 04/03/22 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
BurbMan wrote:
Lantley wrote:
Hopefully this can be corrected by swapping some wires.
Hoses, not wires....The Heartland we just bought has 3 slides, and this is my first rodeo with hydraulic. After the short time we've owned it I can tell you I will never go back to electric-driven rack and pinion. Our sequence is street side bedroom slide, curb side main slide, street side kitchen slide. As Doug said, the hydraulic lines are plumbed that way....when slide 1 is almost home (either in or out), pressure builds and starts moving slide 2, etc. When retracting the slides they go in the same order, not reverse order. Doug knows the most about this, but I think the only way to change the order is to re-route the hydraulic lines and change the order in which the slides are connected from the pump.
I stand corrected.
You know I thought hoses not wires after I had already hit send ..LOL
Sounds like it may not be quite as simple as we hoped but that there is a solution.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Cptnvideo
Arizona - most of the time
Posted: 04/03/22 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
I found the valves. The next time we open slides, I will close 2 at a time to identify and label. So, at least we can open a particular one.
Bill & Linda
Arizona
2019 Dodge Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 3 206AH LiFePo4 batteries
1320Fastback
Vista, Ca
Posted: 04/03/22 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
katysdad wrote:
Changing lines won't change sequence. Lightest or least resistance goes out first. Heaviest last. Same on retraction lightest first heaviest last. Pump is pushing fluid to all 3 cylinders at the same time. Not sure if used anymore but some units a few years back had a manifold near the hyd pump with manual valves you could block off individual slides.
Retractable Landing gears of older airplanes and war birds are similar. If you've ever watched a landing gear transit it can be anything but smooth sometimes as the gear with the least resistance at the time moves then the other. They also didn't put any bigger of a pump than necessary for weight concerns
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
ACZL
UPstate,NY
Posted: 04/04/22 01:49am Link  |  Quote  |  Print  |  Notify Moderator
Our old Cedar Creek Silverback had 3 slides and 1 switch. BR went out/in 1st, then the Main Street side slide (couch/dinette), then the BH was last. All went in in same order they went out.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Lantley
Posted: 04/04/22 05:03am Link  |  Quote  |  Print  |  Notify Moderator
Always compromise in the RV world. My 5 cable driven electric slides are certainly not an enginerring marvel. At times I'm dismayed how fragile the system is. However they can each be operated independently.
I believe that hydraulic slides are a more robust system, but not being able to operate or control them independently is a huge negative to me.
BurbMan
Indianapolis, IN
Posted: 04/04/22 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Lantley wrote:
I stand corrected.
Me too, apparatnly changing the order of the hoses won't do anything.
The video I posted was a Grand Design owner that found where the mfr had installed valves in each slideout line, so you can close the valves to all but the one slide you want to operate. Sounds like this solved the problem for the OP, I have to check now and see if I have a similar setup.
WNYBob
Tonawanda, NY
Posted: 04/04/22 05:33am Link  |  Quote  |  Print  |  Notify Moderator
This is one reason I will not buy a RV that restricts movement when the slides are in!
Lantley
Posted: 04/04/22 06:21am Link  |  Quote  |  Print  |  Notify Moderator
I don't think its as simple as that.
Back to the compromise thing.
I agree no blocking slides is the best arrangement.
I have 5 slides. I do not have full access with slides in however I can get to the bathroom and bedroom.
I cannot get to fridge without opening 1 slide. My slide do operate independently of each other.
Having to move all slides to access fridge would be a deal breaker.
Independent slide control is an important feature for me.
With 5 slides full access with slides in is virtually impossible, but decent access to essential areas is something I can live with.
I seldom need to use RV in turtle (all slides in)mode!
valhalla360
No paticular place.
Posted: 04/04/22 07:26am Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
What creates the sequence? Can the sequence be changed?
One pump feeds two (or more) extension cylinders...the cylinder with the least resistance moves first.
We had this on a 2 slide unit with one button.
Really not a big deal as it only took about a minute for both to be fully extended or retracted.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
CA Traveler
The Western States
Posted: 04/04/22 07:43am Link  |  Quote  |  Print  |  Notify Moderator
This thread illustrates a major buyer oversight - The lack of a complete Pre Delivery Inspection - PDI BEFORE you buy. And it is definitely not the dealers PDI. A long checklist of everything and that includes access with the slides in. For me this requires reasonable access at a rest stop where the slides can't be deployed or parking at a house where the street side slides can't be deployed. And most important is to check the emotion part of the purchase and be prepared to walk.
Buy the rig and 2 weeks later do a dealers PDI is asking for unexpected delays (parts available, tech available, etc) and surprises. Insist on an alternative or move on.
This has been posted many times.
2014 Grand Cherokee Overland
Bob
Page of 7
