RV.Net Open Roads Forum: Fifth-Wheels: Slide design by Grand Design
 > Slide design by Grand Design
Page of 7
way2roll
Wilmington NC
Posted: 04/04/22 07:53am Link  |  Quote  |  Print  |  Notify Moderator
MY FW has controls that allow any of the 3 slides to remain closed. They are switches that close off the lines going to that particular slide. Yours may not have come that way, but since it exists on mine I can only assume you could install such a control. Probably just a rudimentary lever to close off that set of Hydro lines. One lever for each slide.
FlatBroke
CO/AZ
Posted: 04/04/22 08:19am Link  |  Quote  |  Print  |  Notify Moderator
We had Bighorn that had hydraulic slides but there was a valve that had knobs that you could open and close individual slide. Easy to do, had no problem if I only wanted to open a certain slide.
Hitch Hiker
"08" 29.5 FKTG LS
Second Chance
Wherever...
Posted: 04/04/22 08:29am Link  |  Quote  |  Print  |  Notify Moderator
There is a manifold with thumb-twist valves located in the passenger side propane tank compartment. It's not well documented, but you can control which slides go in/out first or not at all by manipulating the valves in this manifold.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
BurbMan
Indianapolis, IN
Posted: 04/04/22 08:47am Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
This thread illustrates a major buyer oversight - The lack of a complete Pre Delivery Inspection - PDI BEFORE you buy. And it is definitely not the dealers PDI. A long checklist of everything and that includes access with the slides in.
This has been posted many times.
Great advice for 5 years ago....demand is so strong now that dealers won't jump through hoops for somebody that MAY be a buyer.
Agree with your comment on slides though, my criteria is access to both fridge and bathroom with slides in.
valhalla360
No paticular place.
Posted: 04/04/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
This thread illustrates a major buyer oversight - The lack of a complete Pre Delivery Inspection - PDI BEFORE you buy. And it is definitely not the dealers PDI. A long checklist of everything and that includes access with the slides in. For me this requires reasonable access at a rest stop where the slides can't be deployed or parking at a house where the street side slides can't be deployed. And most important is to check the emotion part of the purchase and be prepared to walk.
Buy the rig and 2 weeks later do a dealers PDI is asking for unexpected delays (parts available, tech available, etc) and surprises. Insist on an alternative or move on.
This isn't a flaw.
You could note it in the PDI but it wouldn't be justification to reject the unit. (this assumes you have a sales contract already completed and signed)
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Jim-Linda
Livingston, TX
Posted: 04/04/22 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Doug, our HH Champagne with 3 hydraulic slides, does have a switch for each room. I think I would much prefer this method to the one the OP had.
Jim
time2roll
Posted: 04/04/22 10:12am Link  |  Quote  |  Print  |  Notify Moderator
The ultimate solution seems to be adding two more pumps, two more switches and new hoses as needed.
Just money, right?
Not so much a really dumb design but actually a lower cost option.
And since we primarily shop by price....
675w Solar pictures back up
dougrainer
Carrolton, Texas
Posted: 04/04/22 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Jim
Jim I once stayed at a Holiday Inn Express[emoticon] I don't understand your post directed at my comment. I was EXPLAINING how 1 switch systems operate NOT all Hydraulic slide systems. Doug
goducks10
There
Posted: 04/04/22 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Every trailer I've bought when semi interested I have them get the cart battery the lot has and have them run the slide(s) in and out so I can get a look at what I'm getting into.
Waiting until the PDI and finding some poor design things or a dent/scratch here and there is not good. By that time most buyers are so excited and determined to buy that they'll let some QC slip.
In all fairness to the OP it's really tough to do a walk through and catch 100% of all things wrong.
One thing I found is even when just cruising through dozens at an RV show if I'm in one thats caught my fancy I'll take the time to check out the bathroom for usability, the bedroom for walk around space and the slide in out access. You can pretty much tell just looking whether or not you have access with slides in when they're out.
Open and shut doors and drawers. Lots of surprises behind closed doors. We went in one TT once and open the closet in the rear and it was so shallow that you wouldn't be able to hang close in it even though it had a clothes rod. Really?
spoon059
Just north of D.C.
Posted: 04/04/22 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Cptnvideo wrote:
bcbouy wrote:
i have to ask.you didn't notice this when you did the walkthrough? i spent well over an hour doing my walkthrough and went over everything as well as firing up the heaters and running the fridge on all settings, running the slides and awnings,leak tests on the water and propane systems, the whole nine yards.
We had been in the unit twice - the second time a little more thoroughly. We agreed to purchase. Two weeks later after the dealer said everything was ready, we signed all the papers, then got the walk thru. That is when I first noticed just 2 slide switches. Since it was a new 5th, I assumed the dealer went thru all systems before delivery.
First of all, never assume the dealer did anything. Second of all, the system is working exactly as it was designed, so the dealer going through the systems isn't a valid point either way. Third of all, the slides all worked that way before you purchased and you should have made the decision BEFORE agreeing to buy.
That said, this sounds like a big nothing to me. If you like the floor plan, just learn how it operates and don't leave things behind the last slide. I don't see a problem with the design, I see a problem with the thought process behind inspecting the camper and buying it without understanding how it works and making sure it meets my needs...
2015 Ram CTD
2015 Jayco 29QBS
Page of 7
