Cptnvideo
Arizona - most of the time
There has been more than one comment about how I should have done things differently at the buying process. I wish commenters would limit their comments to the subject that was posted instead of berating the OP about the buying process.
I see this on other posts as well - not just mine.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
Michelle.S
Western NY till fall, then Sebring, FL
When you have multi hydraulic slides controlled a single switch, generally the lightest and usually smallest will move first then followed by the next lightest with the heaviest last. And they will generally follow the same retracting.
If you have shut-off valves for the individual slides you can close the ones you don't want to move. But other than that your system is operating exactly as designed and just like every other RV with multi Hydraulic slides controlled by a single switch.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Lantley
Ellicott City, Maryland
The title of this thread is really dumb design, which I agree with.
After reading more I'm finding this design is fairly common. GD is not the only manufacturer using this slide method.
What is also apparent is that many do not understand the importance of the PDI.
A PDI is your only chance to discover any flaws within your unit before you buy it.
Yes the slide issue could have been discovered and resolved sooner, during the PDI one should assume nothing works until it is tested.
That means every drawer, door, latch, switch, window, faucet, plug, slide, genset, stove,oven,water heater,furnace, A/C unit,A.C. outlet,sensor, TV,stereo,lock,remote,drain,valve all needs to be tested/checked out.
Failure to do so exposes the buyer to potential heartache down the road.
I don't fault the OP for not understanding how the slides operate, but I do question how thorough/complete his PDI was.
The PDI maybe the most important part of the process when buying an RV.
I don't think the OP understood the PDI process going into it.
The dealer does not control the PDI the buyer does. I just asked to be left alone and I went through the RV top to bottom. Let everyone involved know that is your intention before signing and accepting RV.
THe dealer will be way more motivated to correct any issues prior to you accepting rig vs. after. Afterwards its all a warranty issues that may put you in a long line. However correcting PDI issues on the front end of the sale keeps you in the front of the line.
A PDI check would not have changed the way the slides operate but it would have led to a more complete explanation of how the slides function including the use of isolation valves that the OP was unaware of.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Cptnvideo
Well said, Lantley.
Michelle.S, thanks to this thread and knowledgeable people, I now understand the system and know about the valves which I have labeled for future use. I am now satisfied with the slide system now that I understand it and know there is a way to open any one particular slide.
Nv Guy
Reno NV
Doug explained it well, as did others. While I understand the OPs issue and how he didn't notice it, this is "fixable" with some solenoid valves, relays and switches for each room.
valhalla360
No paticular place.
time2roll wrote: The ultimate solution seems to be adding two more pumps, two more switches and new hoses as needed.
Just money, right?
Not so much a really dumb design but actually a lower cost option.
And since we primarily shop by price....
Not just lower cost but simpler with fewer things to break and likely less weight which is often a consideration.
Since most people don't fret over the extra 10-15 seconds to open all the slides, it's actually a smart design.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
CA Traveler
The Western States
Only 1 pump is required along with valves, wiring, switches to control each slide. A control board or different switches are required to ensure the owner can only move one slide at a time. Additional weight is small, cost not so much.
For me it's not the time to deploy the slides but the parking situations where all slide deployment is not desired/possible. Apparently some mfgs have an answer with outside manual valves. Like a rest area or street parking at a house, etc. We don't necessarily deploy all slides for 1 night stops. Slide deployment can restrict storage access as another consideration.
My pump and valves are centrally located, 2 slides with 2 rams each means 8 hoses, definitely more expensive. Remote valves would be another option with less hose but individual mounting so not obvious that option is less cost.
valhalla360 wrote: time2roll wrote: The ultimate solution seems to be adding two more pumps, two more switches and new hoses as needed.
Just money, right?
2014 Grand Cherokee Overland
Bob
dougrainer
Carrolton, Texas
I can tell you that even if the OP found this operation NOT to his liking at the PDI, the Factory would not pay to change it. If it is designed that way, then attempting to change a functional working as designed system would not be a warranty issue. Then the OP can make a decision, buy or walk away. This post shows WHY it is important to do the walk thru BEFORE you sign paperwork and take delivery. NEVER BUY AND SIGN PAPERWORK BEFORE THE PDI AND WALK THRU. NEVER NEVER NEVER. This is not a Auto or truck but a mobile house. I have been in the RV business for 50 years and 43 as a RV Technician. I would NEVER deviate from what I just posted and I tell my friends to do the same when they buy a new or used unit from a Dealer. Doug
CA Traveler
The Western States
Good post Doug.
Apparently to many are buying based on their car experience and don't know how to spell PDI and prepay with all emotions on full throttle. And of course the dealer PDI is wonderful.
way2roll
Wilmington NC
After owning several types of RV's I probably wouldn't have thought to go over this on a PDI either. Sure I went over how the slides work, but it may not have occurred to the OP that there is ever a need to open just one slide or any combination. Sounds like the OP found out what he was looking for and that's great. But I know for sure that buying a house - heck designing and building my own, as well as buying cars and RV's, I've always learned quite a few things months after ownership. You just aren't going to know, or even know to ask everything on PDI day. If that were the case this form wouldn't even exist.
2023 FR Sunseeker 2400B MBS
