RV.Net Open Roads Forum: Tech Issues: Compartment latches and locks
 > Compartment latches and locks
IAMICHABOD
Sunny So Cal
Posted: 04/06/22 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
It is amazing that E trailer can sell the same lock that I posted about earlier for $2.20 more........
RV Locks and more
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Gdetrailer
PA
Posted: 04/06/22 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Curly2001 wrote:
The hard locks are the slam latch locks. Would like to replace mine with different keys but I don't think that is possible. Have to lube them every few times we camp to keep them able to lock on the latch side. Use a silcone lube on them to keep them cleaner. Getting to be a real issue.
Curly
Silicone lube is the reason you have to relube often.
Silicon lubes once the transport liquid evaporates doesn't leave behind enough silicon to do any world of good..
Have tried it on vehicle door gaskets when the automotive world got rid of the old rain gutters.. The gutterless doors in the middle of a long cold winter snap end up frozen solid to the gaskets.. Spraying with silicon would only help for one or two times and then freeze up solid..
The exact same thing happens in door locks..
That is why I started using the TriFlow I posted, it is oily, it will leave a oily residue behind and it also contains something far slipperier than silicon called Teflon.. There is a reason as to why they don't use Silicon as a non stick coating on skillets..
The oil in Triflow prevents moisture from attacking the pot metal in the lock. This is very important, unprotected pot metal when it is in contact with water or moisture from the air corrodes into a white powder, the powder helps to jam the lock.. Making things worse is as the potmetal corrodes, it swells up, getting larger in size which combined with the powder ruins the lock.
Spray the Triflow in, insert key, rotate a couple of times and pull key out. Wipe oil on the key off and repeat key in and out a couple of times. This removes extra oil from the key slot.. After that, no more oil on key and your lock will not get stuck. I use this on any lock that is outdoors to prevent freezing in cold weather and rusting stuck. I only have to reapply Triflow once every 5 or so yrs on my outdoor locks..
jodeb720
Denver
Posted: 04/07/22 09:27am Link  |  Quote  |  Print  |  Notify Moderator
I went with these combination storage locks about 8 years ago.
Combination Locks on Amazon
i've never looked back and haven't had any issues with them spinning.
If your existing locks are spinning, the nut on the back has come loose and you're going to need some sort of washer to stop it from spinning.
The cam locks above don't come with washers - so you're going to need to find them online (e.g. McMaster-Carr)
I went with the dark finished locks as the chrome/polished finished ones are harder to read.
(black with white numbers is easier to read at night)
in the 8 years I've had the combo locks, i've never had a problem with them not working well. I've found that the metal behind the lock has gotten bent when DW doesn't full open the lock and the metal of the lock strikes the lip on the inside... but that's operator error not a defect of the lock itself.
