RV.Net Open Roads Forum: Tech Issues: Available Battery Charger(s)
 > Available Battery Charger(s)
Posted: 04/06/22 05:23am Link  |  Quote  |  Print  |  Notify Moderator
I am partial to the Progressive Dynamics 9200. Made in the USA (Marshall, MI) it's a good unit that treats teh battery well.. You can get factory refurbs for around 200 more or less depending on the size.
Battery: My recommendation is one of two
LiFePo4 Battle Born can provide a special Progressive Dynamics converter that is programmed specifically for their LiFePo4 But as you have noted EXPENSIVE. thera are a couple other issues with LI batteries (They do not like COLD).
Good old GC-2 Flooded wet cell (OR GC-12) these are true DEEP CYCLE batteries ideal for RV use The GC-2 is a 6 volt so you need TWO of them in series to make 12 volts (They basically become 4D when properly wired). Treat them as you would a single 12 volt battery.
The GC-12.. IS a 12 volt battery
The 45 amp 9200 is the choce for a GC-12 45 or 60 for a pair of GC-2
StirCrazy
Kamloops, BC, Canada
Posted: 04/06/22 06:48am Link  |  Quote  |  Print  |  Notify Moderator
jodeb720 wrote:
Gents,
He's not going to replace his WFCO power center - so that's off the table.
josh
he doesnt have to change the whole power center he can just change out the converter section which is basicly a charger. if he is going to leave it the same I would sugest he just buy the cheepest GC2 batteries he can find and then its not a big deal to replce them. and external charger just seams like a lot of un nessasary work to me.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
jodeb720
Denver
Posted: 04/06/22 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the suggestions - I'll start doing the research for him now. since he's in Oregon and I'm Colorado, it's hard for me to "help" him with things that are above his pay grade in terms of experience. He doesn't want to make a mistake - so he's looking for something he can 'manage' himself without making a mess out of his battery.
pianotuna
Regina, SK, Canada
Posted: 04/06/22 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Why is solar not on the table?
Regards, Don
jodeb720
Denver
Posted: 04/06/22 10:52am Link  |  Quote  |  Print  |  Notify Moderator
because he's young, and still just "starting out".
He bought a TC a few years ago, he and I worked on it - extensively - and got the existing solar panel hooked up and working, added a sink and water - and made it habitable.
He sold that and purchased a travel trailer for 1000.00 - and parts of the floor were rotting out - he used it last summer - and then sold it for salvage and made a profit from it.
Now he's spent a bunch more money on a TC - which is in really good shape - but right now he's cash strapped.
If he had the extra cash, he'd throw solar, and go with Li for power - but right now he's got the unit and is looking to come up with a way to boondock - on the cheap - until he makes more money and I can go to Oregon (from Colorado) to help him get solar, and better batteries and find more space to store stuff.
the Opposite end of that discussion is my friend who just bought a 40' Toyhauler and is replacing the entire power distribution system that has Charger/Inverter in one device (PD) and purchased four Li batteries so he can run his generator once a day for a couple of hours and recharge enough for his boondocking - but not conserve...
A lot of it has to do with where you are financially in life - and what you can afford versus what's practical.
profdant139
Posted: 04/06/22 11:15am Link  |  Quote  |  Print  |  Notify Moderator
The OP recommended fully charging the battery as soon as you get home -- good advice! But at the risk of stating the obvious, you then have to maintain the charge until the next camping trip. For whatever it's worth, I use a BatteryMinder Plus as my trickle charger.
But it sounds to me like the OP may know more about batteries than I do -- I get about five years out of my group 31 batteries (with about 70 nights a year of camping), and he gets 8 years out of his.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
pianotuna
Regina, SK, Canada
Posted: 04/06/22 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
profdant139,
I managed 9.5 years on marine batteries.
jodeb720
Denver
Posted: 04/07/22 09:19am Link  |  Quote  |  Print  |  Notify Moderator
OP Here. We all know the care and feeding of batteries - especially given the cost for them versus the cost of maintenance (which is relatively cheap).
I've ruined more batteries in my life by adding tap water to them, by not fully recharging and desulfating them periodically.
From the great advice I've been given here in this forum, I've learned and been able to keep my batteries in good shape with minimal loss of capacity because of a few, easy maintenance items.
The best advice given to me recently from all of you was to check the water levels, fully charge, desulfate and disconnect the batteries here in Denver (I was in Los Angeles before) - fully charged batteries don't freeze - and that's not something I would have thought of moving to Denver.
For that Thank you all so much!
For my cousin, he's just starting out on his adventure - and the path of least resistance and lowest cost of maintenance is an external charger - which has a maintenance mode (trickle charger).
He's going to remove his battery when it's not used, slap the charger on it, and store it at his house - not in the TC when not in use.
I know. Not optimal - but it's better than using the WFCO to charge the battery (which could take days if it ever fully charges the battery) and it remains permanently undercharged.
He and I did discuss moving to Li or AGM which is why he's looking at an external charger which is designed to charge all three of the major battery types (FLA, AGM Li). For now though, it's basic maintenance and he can enjoy his new to him TC for the summer - and he can save his pennies until he can upgrade.
