profdant139
Very clever -- just bypass the controller and use another controller near the battery! I'm not sure I will do that -- depends on the cost and my lack of skill -- but that is definitely thinking outside the box.
It's interesting (in a 30,000 foot way) to see myself as a captive of my own assumptions, for example: "Well, the controller is permanently attached, so I guess I am stuck with it."
It is very hard to force myself to think in a non-linear way: what if we ignore the existing controller?? Once someone else points out the obvious alternative (usually DW), I feel humbled. It is not a pleasant sensation.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
pianotuna
Regina, SK, Canada
Munches on humble pie on sometimes a daily basis!
Regards, Don
profdant139
The only thing worse than humble pie is when it comes with a side order of crow. Don't ask how I learned this.
SteveAE
Bend, Oregon
Short of modifying your existing system (or better yet, building your own system that will better work for you....panels and a controller are super cheap these days), I like the idea of having two different length cables that you can mix and match as needed. Just keep in mind that every time you have a connection point there is an increase in resistance.....and a corresponding voltage drop.
But, keeping with my theme of looking for alternative solutions (I guess they call it thinking outside the box) here are some more (dumb???) ideas:
- Get a second portable system that you put in parallel with your existing system and double the fun of chasing the sun around.
- Have a second battery that you put right by your panel, then swap batteries as needed. If you can't bring Mohammad to the mountain, then move the mountain to Mohammad...or some such nonsense.
- Put another cable in parallel with your existing cable.
BFL13
Victoria, BC
Once in the sun all day worth rotating tilted array three times.
Sunset to SE
Mid morning to S
Mid afternoon to SW
Also tilt lower mid day with sun higher
Eg 130W in May at 49N daily AH haul
Flat 56
South tilted all day 70
Tilted rotate three times 90
OP 110AH batt 50% needs 55 plus 5 for heat so
60 is in range after using some to run things during daylight too and 120W other times of year and latitudes
edited 04/08/22 09:38am by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
