johndeerefarmer
In Texas the new Toot n Tootems has RV gas pumps that are away from the other pumps and easy in, easy out. I now use them because of this feature..
2020 Ford 350 6.7 PSD & 2017 F150 3.5 EB max tow
GD Reflection 29rs
Curly2001
Tucson, Arizona
Just watch the distance between the front of the store and with the space to the first set of pumps. Often times you can go to the right of the first set of pumps, past the front of the store and then pull to the last set of pumps for fuel on your left. Did it alot on the way to Oregon from Arizona. Also at Love's truck stops, often there is quite a bit of space from the front of the store to the pumps which really helps position for fuel, especially gas pumps.
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
Hammerboy
Zeeland, MI
BarneyS wrote: In over 35 years of towing a large travel trailer, i only had to back out of a station twice _ both times back into a busy street. Had no problem with my wife stopping traffic and me slowly backing up. Cars stopped and no one honked.
We always gassed up or fueled up at local gas stations that had diesel fuel. Never a problem.
My advice, learn to back your rig, use the outside pumps, and don’t worry about it. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Barney
Thats always my fear, having to back out of a station with our fifth wheel. I did the other day have to pull into a local station the other day with the fifth wheel which also had our kayak trailer behind it. I scoped it out first before I pulled in, hard to back out with two trailers :-(
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
BarneyS
S.E. Lower Michigan
I would not even attempt to back up with two trailers- especially the kind we have. I used to drive truck and still marvel at the ability of some of these drivers pulling and backing two gravel or dirt trailers.
Had one the other day pull in to a new homesite near us so I stopped to watch what he was going to do. Instead of dropping the 2nd one like I, and most others would probably do, he proceeded to back the thing up around the corner and into the lot. I could not do that in a million years! Quite impressive.
Barney
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
ol Bombero-JC
Execute: "Plan Ahead!" when you're down to 1/4 tank of fuel.
Never found a station I "needed" for diesel -with 5th hitched- if I 'executed' properly.
*If* you can't do the Boy Scout thing - carry a 5gal can of diesel.
*If* you can't remember to do either one - practice backing (a lot).
![awink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/awink.gif)
Mondooker
Florida Gulf Coast
Hi ol Bombero-JC, I’m sure there’s something in there somewhere I can use. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
One of them is get gas (not diesel) well before you need it! See how I paraphrased there? Yah I got the 7.3 Godzilla engine. That is one fantastic engine but it does requiring refueling and that’s for sure!
mlight
Northeastern PA
This reminds me of the time i mis-calculated my range when coming into the metro DC area. I pull a 43ft triple axle and thought i could make it outside the city where easier accessible fuel stations exist. Ended up running down to almost empty before i had to drop the trailer off at a walmart with the wife and get diesel at a low canopy fuel station. Now i start looking for fuel around half a tank and plan my route to pilot's, TA's ect.
2016 Jayco Seismic 4250
43' Triple Axle Toy Hauler
Mondooker
Florida Gulf Coast
Hi mlight and I hear that. I’ll do that as well… Almost out of gas with no place in sight with a large 5’er is no fun!
Lantley
Ellicott City, Maryland
mlight wrote: This reminds me of the time i mis-calculated my range when coming into the metro DC area. I pull a 43ft triple axle and thought i could make it outside the city where easier accessible fuel stations exist. Ended up running down to almost empty before i had to drop the trailer off at a walmart with the wife and get diesel at a low canopy fuel station. Now i start looking for fuel around half a tank and plan my route to pilot's, TA's ect.
I live just north of DC metro area. One of the reasons I have my Enduraplas 26 gallon aux. tank is it ensures I have enoufh fuel to clear the DC metro area when traveling from the south.
Getting fuel in the DC metro area is a hassle.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
msmith1.wa
Tacoma, WA
I recently added an in bed auxiliary gas tank, but before that I never traveled without at least one five gallon gas can. When my current truck was two or three years old we were on a trip and the truck was struggling to maintain 60mph on a flat interstate. Pulled over, nothing was obviously wrong. Gas gauge was showing 1/4 tank DIC was showing somewhere around 60 miles of range. Get back on the interstate and now 50mph is max and the it dies. Luckily we were close to a rest area, coasted into there. No change in gas gauge reading. I pour the gas from the can into the tank. Truck fires up and runs like it should. Something must have caused the gauge to hang up at a 1/4 tank. Hasn't happened again since.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
