RV.Net Open Roads Forum: Fifth-Wheels: Getting gas with long trailer?
 > Getting gas with long trailer?
Page of 5
ReneeG
Meridian, Idaho
Posted: 04/07/22 07:24am Link  |  Quote  |  Print  |  Notify Moderator
BurbMan wrote:
Mondooker wrote:
Hi Lantley, I think that’s absolutely right. Know in advance where you want to stop to fill up and Google Earth it to make sure the place is set up right. Someone said earlier if push comes to shove you can always unhook. And that’s true, a fifth wheel makes it pretty easy. But far better to find a station where that’s not necessary.
With much respect to Lantley, you are overthinking this. Stop when you need fuel and if there are choices, you go with easiest in/out. If not then you go and fuel and back out onto the road like we have all done. No need to ever unhook your trailer just to fuel,
I second this. Don't overthink it. Two things we look for 1) the height of the canopy for our FW - we have our height laminated and taped to the upper edge of the inside windshield to be able to glance at quickly and 2) easy in and out. We've never had to unhook and have, although rarely, had to drive in and back out either due to the height of the canopy or cars blocking the exit. I get out and spot hubby. It works and let me tell you, people are very accommodating when we've had to do this. Oh, and we stop and top off at places we can get in and out easily when we really don't need gas, but that gives us the leeway when we can't find a gas station to get in.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
tomman58
Southeast Michigan
Posted: 04/07/22 07:33am Link  |  Quote  |  Print  |  Notify Moderator
think every flying J has a set of gas pumps separate from the normal gas ones for RVs and such. I always had a problem with their pricing even though we got diesel . I've seen motorhomes having to disconnect their toads to do pumps. Good luck
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
Thermoguy
Graham, WA
Posted: 04/07/22 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Wow, so many people overthink this. Getting gas is simple and many gas stations have large areas that are not an issue for a truck and trailer. I have a diesel but never go to the "truck" island, always the same side as vehicles. It's probably harder to get diesel as there are limited pumps and you often have to wait for an open pump. But, if you are traveling on the interstate or highway, most if not all stations are going to have ample room. I can't even recall backing out unless there is a car at the pump in front of me and I can't go forward or don't want to wait. Just look before you drive in the driveway, if it is too tight, go to another one, usually across the street. I think I spend more time looking for the price then looking if I can get in and out. This really is a non issue, or at least not worth stressing or even planning in advance. I have never looked at Google to see if the station is large enough. If you wanted to gas up in the city, then you might have to think a little harder for a station with room, but no the interstate, don't even worry...
Lantley
Ellicott City, Maryland
Posted: 04/07/22 10:30am Link  |  Quote  |  Print  |  Notify Moderator
You claim that it is not an issue then you mention if it's too tight go across the street......THe idea is to pull into an accesible place the 1st time!
Getting gasoline while hooked often requires effort.It's not as easy as getting diesel.
It's not the issue of our lifetime, but it is worth some discussion and often requires some planning/scouting.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Mondooker
Florida Gulf Coast
Posted: 04/07/22 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Hi guys, I want to thank you one and all for your comments. I was afraid when I made the post I’d get something like “that is such a stupid question.”
One thing that brought up the question is I was at Walmart the other day. Plenty of room to get in and plenty of head space. But you’d have to back out, something I’d not want to do in a busy place.
ford truck guy
Pennsylvania
Posted: 04/07/22 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Whenever I go to a NEW destination, I always do a google map of the route.. I figure out the mileage and look on google street view to scope out the fuel stops along the route, in the range I am usually at..
I have never had an "OH CR@P " moment since doing it that way.
I did once have an HEIGHT issue down south... almost took down some low hanging lights at a smaller station. The Canopy had the height, the lights hanging under the canopy, not so much.. But ALMOST didn't count that day ! ! !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Mondooker
Florida Gulf Coast
Posted: 04/07/22 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
RVing is not for those who dislike paying attention and sometimes following the rules. Do you find that as a rule, people are pretty good about giving extra room and/or hanging back when needed? I’ve had little trouble with folks while driving a motorhome. I would think the same is true pulling a fifth wheel?
I’ve always used diesel pumps in the past without issue using truck stops. It’s nice to know that FlyingJ has pull through RV gas pumps. After reading this thread I’m a lot more confident in getting gas from non-truck stop stations.
NamMedevac 70
Reno
Posted: 04/07/22 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
temporarily unhook the trailer. Extra work is good for the
tomman58
Southeast Michigan
Posted: 04/07/22 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Not worthy of even a thought
BarneyS
S.E. Lower Michigan
Posted: 04/08/22 07:47am Link  |  Quote  |  Print  |  Notify Moderator
In over 35 years of towing a large travel trailer, i only had to back out of a station twice _ both times back into a busy street. Had no problem with my wife stopping traffic and me slowly backing up. Cars stopped and no one honked.
We always gassed up or fueled up at local gas stations that had diesel fuel. Never a problem.
My advice, learn to back your rig, use the outside pumps, and don’t worry about it.[emoticon]
Barney
Not towing now.
Page of 5
