mooky stinks
Cicero,NY
I ordered 2 27DCs from the Walmart website yesterday. The description stated an amp/hr rating of 109. When I picked the batteries up they had hold stickers on top with my name etc. When I got them home and peeled the stickers off they had a rating of 80 amp hours @ 20hr on the label. They do weigh what the description states @ 50.2lbs each. I’m pretty sure Johnson Controls were making batteries for them and they have been bought out by Clarios? I’m not familiar with this 20hr style of rating either. There is some mention of this in some of the reviews but nothing more than someone returning the batteries for this reason. Did I get what I wanted or is there something more to this?
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
MNRon
Tennessee
If the sticker says 80AHr, that's probably what you got. 20hr run down rate is typically how batteries are classified for capacity, things like 'cranking amps' don't apply for camping use. If you're installing two, you'll probably get more capacity (as well as battery design robustness) by installing two 6v golf cart batteries in series. Sams and Costco seem to have the best deals on these typically.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
Near Mammoth, California
Twenty-nine amps is significant when talking about totals of 218 vs. 160. I’d return them and ask for what was advertised. Take your written proof.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mooky stinks
Cicero,NY
I did just look at the website photo of the battery and it shows on the label: 109 amp hrs @ 1 amp
VS what I received which states 80 amp hrs @ 20hrs. I can’t find anything that states if these two ratings are just a number game or they truly are different.
BFL13
Victoria, BC
20 hr rate is 4 amps If you draw it down at 1 amp it lasts longer Not a scam, but a sales trick to use the 1 amp rate
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
red31
Dallas
from a JCI 2003 spreadsheet showing amp hours vs constant draw down load
2oldman
NM
All deep-cycle batteries I've seen are rated nominally at 20 hours.
Skibane
San Antonio, TX
mooky stinks wrote: I did just look at the website photo of the battery and it shows on the label: 109 amp hrs @ 1 amp
It's the same battery, just being tested with two different loads.
At higher loads (i.e., more amps), the battery has less effective capacity, because higher loads cause more of the battery's power to be wasted as heat. With more power wasted as heat, less power is available for whatever you're powering.
KD4UPL
Swoope, VA
Just about all Group 27 batteries are, give or take, about 75 amp hours. Yours are 80 so that's on the upper end. Rating them with a 20 hour draw is the industry standard.
A manufacturer can rate them at any draw they want for marketing purposes. Apparently yours are about 109 AH at what is roughly a 100 hour rate. I suspect if you tested them at an 80 amp draw you might only get 1/2 hour making them 40 AH at that rate.
All the numbers are correct, it's called the Peukert effect if you want to read all about it.
Basically their marketing guys used a non standard number to make the advertising look better. It's not wrong, just a little sneaky.
Skibane
San Antonio, TX
KD4UPL wrote: Basically their marketing guys used a non standard number to make the advertising look better. It's not wrong, just a little sneaky.
If they used a 0.001 amp load, they could probably get 150 AH out of it!
