RV.Net Open Roads Forum: Class A Motorhomes: Lubricant - Need Quick Answer
 > Lubricant - Need Quick Answer
FloridaRosebud
Melbourne
Posted: 04/08/22 08:08am Link  |  Quote  |  Print  |  Notify Moderator
We are leaving tomorrow around 8am for a 2600 mile SE US trip. I have a silly problem, but wanted to see people's thoughts. We have an electric awning, which was installed at the Perry FMCA show in 2019. When rolling it out it has begun sticking, resulting in me having to go out and tug on each side, releasing the arms from the mounts. My guess is there is a slight misalignment, as this just started. But I don't have time to dig into very deeply. My current thought is to use vaseline and lube the arms where they go into the mount. A temporary fix for sure, but again, not a lot of time to deal with this before tomorrow morning. Thoughts???
Al
way2roll
Wilmington NC
Posted: 04/08/22 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Vaseline is petroleum based and could affect the surface it's put on and it may collect dust. I would opt for a dry silicone spray lube. Funny, as a cyclist I always have dry chain lube. I use it for a lot of things other than bike chains.
2023 FR Sunseeker 2400B MBS
bgum
South Louisiana
Posted: 04/08/22 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Why not stop using it until you can get it fixed?
FloridaRosebud
Melbourne
Posted: 04/08/22 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Because we're leaving in the morning for a 7 week trip, and need to use the awning. I can continue to pull the arms free, but I just want to do something simple to get us by until we return.
Al
fishingbob61
cookevill tn
Posted: 04/08/22 08:54am Link  |  Quote  |  Print  |  Notify Moderator
spray it with silicon spray or WD40
Bob and Sue
51 years camping
2005 Fleetwood Bounder DP
2004 Chevy. Tahoe
Southern California :(
Posted: 04/08/22 08:59am Link  |  Quote  |  Print  |  Notify Moderator
I vote trying silicone spray but the “real” answer is to have the problem fixed correctly.
sundancer268
Charlevoix
Posted: 04/08/22 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Use a dry silicone spray, Vaseline will attract road dirt and could make the problem even worse.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2019 Jeep Cherokee Trailhawk Elite
Road Master Sterling All-Terrain, Airforce One
Sjm9911
New Jersey
Posted: 04/08/22 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Is the awning rolled up evenly? If not it will bind. On your trip you can see this and ajust the tenting as needed.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
FloridaRosebud
Melbourne
Posted: 04/08/22 09:55am Link  |  Quote  |  Print  |  Notify Moderator
I know the "real" answer but there is just not time before I leave. It does not appear to be misaligned based on the eyeball test when it's rolled up.
Silicone it is....thanks!!
Al
midnightsadie
ohio
Posted: 04/08/22 11:07am Link  |  Quote  |  Print  |  Notify Moderator
nothing oily,it,ll stain
