HarleyEnough
PA
Here's an interesting new product coming to help reduce damage from tire blowouts. Looks like it will be available sometime this summer.
Thoughts?
https://rv-de-fender.com/lets-go/?referral=2dfh8xf&refSource=copy
2011 Dodge Ram Laramie 3500 Crew Cab Long Bed SRW
2019 Raptor 421CK Full Body Paint
BurbMan
Indianapolis, IN
Interesting idea, but to me this treats the symptom, not the cause.
way2roll
Wilmington NC
What is it? None of the links work on the page.
2023 FR Sunseeker 2400B MBS
fj12ryder
Platte City, MO
Yeah, that's the whole idea behind it, to prevent damage form the blown tire, not prevent it, since blown tires can happen for many reasons. But I do wonder how much protection you'll get from the sheet metal, it's barely over 1/16" think. Those exploding tires have a not of energy to be diverted.
Howard and Peggy
"Don't Panic"
HarleyEnough
PA
It says backing plate is 1/8" and arch is 14 guage. Although I don't know if that would be enough to hold up to a shredding tire. Also I don't know how it would work inside the wheel well of the RV as it would move up and down with the axle and wheel (not connected to the frame or body of the RV).
Wade44
Ohio Farm Country
HarleyEnough wrote: It says backing plate is 1/8" and arch is 14 guage. Although I don't know if that would be enough to hold up to a shredding tire. Also I don't know how it would work inside the wheel well of the RV as it would move up and down with the axle and wheel (not connected to the frame or body of the RV).
I would expect to have a mangled 1/8" backing plate and a twisted up 14 gauge sheet metal arch to remove after the blowout in addition to the normal plastic or thin gauge sheet metal wheel well, the plastic skirt, and possibly twisted up wiring, cracked plumbing etc.
2018 Marathon H3-45
2019 GMC Sierra Denali (Toad)
2012 Grady White 271 Canyon
fj12ryder
Platte City, MO
Wade44 wrote: HarleyEnough wrote: It says backing plate is 1/8" and arch is 14 guage. Although I don't know if that would be enough to hold up to a shredding tire. Also I don't know how it would work inside the wheel well of the RV as it would move up and down with the axle and wheel (not connected to the frame or body of the RV).
I would expect to have a mangled 1/8" backing plate and a twisted up 14 gauge sheet metal arch to remove after the blowout in addition to the normal plastic or thin gauge sheet metal wheel well, the plastic skirt, and possibly twisted up wiring, cracked plumbing etc. Yeah, they tout on their website that you just need to change the tire after a blowout since their product will protect the trailer. Methinks that just ain't gonna happen.
I would think it would mount very close to the tire, so there would be sufficient clearance between the De-Fender and the trailer body. But it would have to leave room for some tire expansion with heat. And it would make changing tire sizes problematical.
Personally I think anything strong enough to protect against a blowout is going to be very heavy. Probably too heavy to be practical.
Skibane
San Antonio, TX
fj12ryder wrote: I would think it would mount very close to the tire, so there would be sufficient clearance between the De-Fender and the trailer body. But it would have to leave room for some tire expansion with heat.
Airflow to cool the tire is another consideration.
On dualies, the weight capacity of each tire is often de-rated somewhat, due to the reduced airflow between the tires.
Retired JSO
North Georgia Mountains
I’ve blown 2 tires in the past 15 years on trailers. Each time, the tire damaged the outer fender, no damage inside the wheel well.
phillyg
SWFL
Their site sucks. Best I could determine is there're two products, one that shields the trailer under-carriage from damage, and a "tire band" to assist a motorized RV, or a tow vehicle. Frankly, I'm wouldn't be concerned about the trailer tires because its unlikely to cause a loss of control. Tire bands have been around for years. I would consider bands for front wheels because those are the ones likely to cause a vehicle to swerve.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
