jsummers72
Alaska/Arizona
I have to store my rv in AZ for 4 months. I won’t be able to check on it, cause I live in AK. I’m wondering about leaving a Battery Tender attached for that long. I have covered storage. I have a battery cutoff in a new Arctic Fox tt. After checking water level- Should I … leave cables/wires attached to battery as they are; turn the cutoff switch ( disconnecting it from the rV) and then attach the Battery Tender? Everything I read say check water level monthly, but I can’t do that. Advise pls. Thnx in advance.
2oldman
NM
My advice is to disconnect the negative battery cable. I do that with my car, and 6 months later it starts right up.
edited 04/09/22 01:21pm by 2oldman *
Krusty
Calgary, Alberta,Canada
I would charge the battery completely and disconnect it
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Fisherman
Angus, Ontario, Canada
I have 3 battery tenders, one for my ATV and the other 2 do the boat battery and trailer battery. During the off season, they stay connected ALL the time and plugged in. I have never had to add water to the batteries even after 6 months of maintenance. They are made to stay connected and keep the batteries from sulfating. A couple of them have lasted 12 years, boat and RV 11. I'm pretty sure I'm doing something right.
rk911
DuPage County
jsummers72 wrote: I have to store my rv in AZ for 4 months. I won’t be able to check on it, cause I live in AK. I’m wondering about leaving a Battery Tender attached for that long. I have covered storage. I have a battery cutoff in a new Arctic Fox tt. After checking water level- Should I … leave cables/wires attached to battery as they are; turn the cutoff switch ( disconnecting it from the rV) and then attach the Battery Tender? Everything I read say check water level monthly, but I can’t do that. Advise pls. Thnx in advance.
we usually snowbird between early January and mid-to-late May. while we're gone I leave battery tender devices on both of our other vehicles here at home. never have had a problem.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Cambria, California area
I’d disconnect the battery and hook up a battery tender.
KD4UPL
Swoope, VA
If your battery is fully charged and then disconnected there's not need to have it on a charger for 4 months. If it goes dead in that amount of time it was bad anyway.
fj12ryder
Platte City, MO
I would not rely on a battery disconnect to completely remove all the battery draws. Personally I would put a battery maintainer on it, after disconnecting the negative battery cable, a good quality one. Arizona gets hot and I've read that the heat is harder on disconnected batteries than the cold.
Howard and Peggy
"Don't Panic"
garym114
Bluff Dale, Texas
Disconnect the negative cable from the battery. I have always done this even though my storage facility has power.
No surprises, no need to add water, very small voltage drop.
Seattle Steve
Tucson
2oldman wrote: My advice is to disconnect the negative battery cable. I do that with my car, and 6 months later it starts right up.
Pretty amazing that it starts right up with the negative battery cable disconnected!
