RV.Net Open Roads Forum: Tech Issues: Battery tender & storage
 > Battery tender & storage
Page of 7
jsummers72
Alaska/Arizona
Posted: 04/09/22 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I have to store my rv in AZ for 4 months. I won’t be able to check on it, cause I live in AK. I’m wondering about leaving a Battery Tender attached for that long. I have covered storage. I have a battery cutoff in a new Arctic Fox tt. After checking water level- Should I … leave cables/wires attached to battery as they are; turn the cutoff switch ( disconnecting it from the rV) and then attach the Battery Tender? Everything I read say check water level monthly, but I can’t do that. Advise pls. Thnx in advance.
2oldman
NM
Posted: 04/09/22 09:39am Link  |  Quote  |  Print  |  Notify Moderator
My advice is to disconnect the negative battery cable. I do that with my car, and 6 months later it starts right up.
* This post was edited 04/09/22 01:21pm by 2oldman *
Krusty
Calgary, Alberta,Canada
Posted: 04/09/22 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I would charge the battery completely and disconnect it
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Fisherman
Angus, Ontario, Canada
Posted: 04/09/22 11:36am Link  |  Quote  |  Print  |  Notify Moderator
I have 3 battery tenders, one for my ATV and the other 2 do the boat battery and trailer battery. During the off season, they stay connected ALL the time and plugged in. I have never had to add water to the batteries even after 6 months of maintenance. They are made to stay connected and keep the batteries from sulfating. A couple of them have lasted 12 years, boat and RV 11. I'm pretty sure I'm doing something right.
rk911
DuPage County
Posted: 04/09/22 11:45am Link  |  Quote  |  Print  |  Notify Moderator
we usually snowbird between early January and mid-to-late May. while we're gone I leave battery tender devices on both of our other vehicles here at home. never have had a problem.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Southern California :(
Posted: 04/09/22 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
I’d disconnect the battery and hook up a battery tender.
KD4UPL
Swoope, VA
Posted: 04/09/22 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
If your battery is fully charged and then disconnected there's not need to have it on a charger for 4 months. If it goes dead in that amount of time it was bad anyway.
fj12ryder
Platte City, MO
Posted: 04/09/22 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
I would not rely on a battery disconnect to completely remove all the battery draws. Personally I would put a battery maintainer on it, after disconnecting the negative battery cable, a good quality one. Arizona gets hot and I've read that the heat is harder on disconnected batteries than the cold.
Howard and Peggy
"Don't Panic"
garym114
Bluff Dale, Texas
Posted: 04/09/22 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Disconnect the negative cable from the battery. I have always done this even though my storage facility has power.
No surprises, no need to add water, very small voltage drop.
Seattle Steve
Tucson
Posted: 04/09/22 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty amazing that it starts right up with the negative battery cable disconnected! [emoticon]
Page of 7
