RV.Net Open Roads Forum: Class A Motorhomes: Tow vehicle
 > Tow vehicle
Onyrlef
Plano, Tx
Posted: 04/09/22 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
In the process of purchasing a 2016 Jayco Alante with V10. Plan to tow a 2011 Frontier (Automatic) after I have the drive shaft disc. installed as well as Blue Ox plates, brake actuator and etc. The tow capacity of the TV is 5k. The Frontier is about 4.25k, if I load it w/ a couple Kayaks and misc gear I'll be pushing up on the tow capacity. Anybody towing a heavier rig like the Frontier with a V10? Any pointers? Transitioning from a Trailmanor, so this will be a different ballgame. Thanks
theoldwizard1
SE MI
Posted: 04/09/22 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
If you have never had a motorhome with the Ford V10, you should know it likes RPMs ! And gas !!
grldst
Dallas, GA
Posted: 04/09/22 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I run a 2000 Rexhall Aerbus with a V-10 for a while. I towed a Chevy Suburban from Atlanta, GA to Bozeman, MT and back without any issues. Over the yrs I also have owned gas RV's with the Ford 460 and some with the Chevy 454. The V-10 was superior in all ways.
wildtoad
Blythewood, SC
Posted: 04/10/22 04:28am Link  |  Quote  |  Print  |  Notify Moderator
Don’t guess. If you can load the Frontier will all you expect to be loaded in or on it and get it weighed with full fuel. Do the same with the mh when you get it. Not sure how much it weighs but we tow a 2015 Jeep Wrangler 2dr hard top with a few hundred pounds of stuff with our 2016 V10 six speed Newmar. Works great. Yes it will churn out 4K plus rpm’s when going up steep inclines, but it makes it up every time, passing most trucks. The V10 also does a great job going down the same inclines but down shifting. (Also can be a bit noisy).
And just to set expectation’s in the six years we’ve owned the thing, the V10 chassis as been wonderful, but has never seen a mpg number of 8 or above. Most 7’s sometimes 6.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
way2roll
Wilmington NC
Posted: 04/10/22 06:12am Link  |  Quote  |  Print  |  Notify Moderator
How do you know you have the capacity to tow all 5klbs? I can't find GCWR for your MH. Have you weighed the rig loaded for travel and subtracted from the GCWR? You may find you don't have that much capacity. Your tow capacity is the LESSER of the weight of the MH loaded for travel minus your GCWR or the hitch rating. I assume this RV has a 5k hitch but that does not mean you can actually tow that much. You have to weigh it and do the math.
* This post was edited 04/10/22 06:20am by way2roll *
dodge guy
Bartlett IL
Posted: 04/10/22 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I tow a 13 Explorer with a kayak on the roof as well as up to 4 bikes on the back. I’ve towed this out to CO up in the mountains with no issues. The Explorer is pushing 5k lbs loaded like that.
Don’t be afraid to let the V-10 rev, it needs the RPM to keep moving. 4000-4500 rpm is normal in second gear going up a mountain at 45-50mph! Loaded I’m right at 24k lbs. make sure you always have a tow Haul engaged.
I have since installed a tune from 5star. I haven’t been in the mountains with it, but it does make a difference.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Onyrlef
Plano, Tx
Posted: 04/11/22 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys, my expectations for the 3 valve V-10 are 7-8 mpg. As far as weighing I know what the Frontier weighs, what the kayaks weigh and will get pretty close on the misc. so I'll be in the ballpark of 5k anywsy. Just kinda Wanted to check around before I invest in the drive shaft disc., front plates and the blue ox progressive brake set up. That said, are you in tow haul on flat ground as well as in the mtns?
dodge guy
Bartlett IL
Posted: 04/12/22 04:47am Link  |  Quote  |  Print  |  Notify Moderator
I run in T/H whenever I start the MH. The MH is always loaded, so it’s always hauling.
Your expectation of 7-8 is a bit optimistic. Expect 6, 7 if you’re lucky! Knesset you drive 55 on every interstate out there.
FloridaRosebud
Melbourne
Posted: 04/12/22 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, we're towing an Acadia, with some items loaded. Weighs close to 5K. On this trip so far we're getting 5.85 mpg with our V-10. On Saturday we had 20-30 mph winds with 40 mph gusts hitting us from about a 30 degree angle most of the way. It was pretty brutal driving, and I'm sure lowered the gas milage as well. All that said, the V-10 is a solid engine and will get you there. And tow haul is always on as well. As others have said, don't be afraid of 4,000 rpm.
Al
way2roll
Wilmington NC
Posted: 04/12/22 05:41am Link  |  Quote  |  Print  |  Notify Moderator
I think you missed my point. Sure it's good to know what the Frontier weighs, I am talking about weighing your motorhome. Your towing capacity is based on the loaded weight of the MOTORHOME minus it's GCWR. That is how much you can tow. It doesn't matter that they put a 5k hitch on it. What matters is that the chassis, brakes, tranny etc of the motorhome can safely tow that much car. Your motorhome has a gross combined weight rating. That means how much the motorhome was designed to carry and tow. When you load the motorhome for travel, (food, water, fuel, clothes, gear) and weigh it, subtract that from the GCWR. and THAT will tell you how much you can actually tow. My guess is, your car on that motorhome is too heavy, but the numbers don't lie. You just need to know the numbers.
I am not trying to be the weight police, but you might want to know this before you invest a bunch of money on bars, drive shaft disconnect, brakes etc only to find out the motorhome you are buying can only safely tow 2000 lbs. Just because it has a 5k hitch does not mean it can actually tow 5k. You'd be surprised the number of small Class A's that can't carry much more than their dry weight out of the factory, and then slap a 5k hitch on it.
 > Tow vehicle
