mountainkowboy
Socal/NE Oregon
We towed our Ranger home on a car trailer when we snap bought our 07. Went a crossed the scale at 5,500lbs on the trailer. Other than being a little slower going up hills, it didn't really care much. Lost 1 mpg due to the weight and yes, the V10 like to do 4K up hills. We are in the process of setting up the Ranger to be flat towed with the Harley in the bed. Ranger is a bit lighter than your Nissan though. Curb on ours is 3,200lbs they say. I will weigh everything after getting it outfitted though, so I know.
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
Onyrlef
Plano, Tx
Is your Ranger automatic? If so are you doing the driveshaft disc. or the pump. How are you going to handle braking? Guessing you should be okay on weight even w/the Harley.I've always heard those limits are from the lawyers anyway and you can fudge on them some. Doubt I'd be in TH without a dinghy but I'll definitely use it when towing, it knocks mileage down a bit but is a transmission saver. I don't plan to cruise at over 58 anyway.
way2roll
Wilmington NC
Onyrlef wrote: I've always heard those limits are from the lawyers anyway and you can fudge on them some.
They aren't. The limits are are from the engineers. I guess they could be used by lawyers in an accident for being over the limit.
2023 FR Sunseeker 2400B MBS
FloridaRosebud
Melbourne
Onyrlef wrote: Is your Ranger automatic? If so are you doing the driveshaft disc. or the pump. How are you going to handle braking? Guessing you should be okay on weight even w/the Harley.I've always heard those limits are from the lawyers anyway and you can fudge on them some. Doubt I'd be in TH without a dinghy but I'll definitely use it when towing, it knocks mileage down a bit but is a transmission saver. I don't plan to cruise at over 58 anyway.
Those numbers are from the engineers, not lawyers (I'm an engineer). While there are safety factors it doesn't mean you should ignore them. The lawyers will sue you if you do.
Al
dodge guy
Bartlett IL
FloridaRosebud wrote: Onyrlef wrote: Is your Ranger automatic? If so are you doing the driveshaft disc. or the pump. How are you going to handle braking? Guessing you should be okay on weight even w/the Harley.I've always heard those limits are from the lawyers anyway and you can fudge on them some. Doubt I'd be in TH without a dinghy but I'll definitely use it when towing, it knocks mileage down a bit but is a transmission saver. I don't plan to cruise at over 58 anyway.
Al lawyers and bean counters most definitely have a say in stuff like this!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
FloridaRosebud
Melbourne
dodge guy wrote: FloridaRosebud wrote: Onyrlef wrote: Is your Ranger automatic? If so are you doing the driveshaft disc. or the pump. How are you going to handle braking? Guessing you should be okay on weight even w/the Harley.I've always heard those limits are from the lawyers anyway and you can fudge on them some. Doubt I'd be in TH without a dinghy but I'll definitely use it when towing, it knocks mileage down a bit but is a transmission saver. I don't plan to cruise at over 58 anyway.
You can believe that if you'd like, but having worked with Attorneys in the liability and insurance fields for over 15 years, I can assure you the ratings for hitches, tow bars, and so on are established by engineers.
Al
dodge guy
Bartlett IL
FloridaRosebud wrote: dodge guy wrote: FloridaRosebud wrote: Onyrlef wrote: Is your Ranger automatic? If so are you doing the driveshaft disc. or the pump. How are you going to handle braking? Guessing you should be okay on weight even w/the Harley.I've always heard those limits are from the lawyers anyway and you can fudge on them some. Doubt I'd be in TH without a dinghy but I'll definitely use it when towing, it knocks mileage down a bit but is a transmission saver. I don't plan to cruise at over 58 anyway.
Al
And then derated by lawyers! Having worked with manuf I know the real ratings on axle and wheel assemblies. They are far higher than what the bean counters and lawyers last say is!
wildmanbaker
Kennewick, Washington
The limit is imposed by the MH manufacture, not the chassis manufacture. Slide under the rear of your MH and look at the cobbled-up mess that they used to extend the rear of the chassis for the receiver hitch and to support the rear of the MH.
Wildmanbaker
way2roll
Wilmington NC
Never understood the mentality to spend all this money on an Rv, tow vehicle, bars, plates etc, a combo that weights 20-40k lbs rolling down the road and not taking the time to do it the right way. And further to shrug off the engineers who design them and their ratings as the fault of bean counters and lawyers. What agenda does an attorney or accountant have to take the recommendation of an engineer - who could be relied on for expert testimony - ignore that and falsely lower a rating on a MH? Especially given that some RV's have really high tow ratings. It's nothing more than a unsubstantiated excuse for not doing things right. Things happen when you exceed the capacity that wouldn't happen if you didn't. And it's not just yourself you put at risk, it's everyone on the road near you.
FloridaRosebud
Melbourne
dodge guy wrote: FloridaRosebud wrote: dodge guy wrote: FloridaRosebud wrote: Onyrlef wrote: Is your Ranger automatic? If so are you doing the driveshaft disc. or the pump. How are you going to handle braking? Guessing you should be okay on weight even w/the Harley.I've always heard those limits are from the lawyers anyway and you can fudge on them some. Doubt I'd be in TH without a dinghy but I'll definitely use it when towing, it knocks mileage down a bit but is a transmission saver. I don't plan to cruise at over 58 anyway.
Al
Then we will just have to agree to disagree. They might have been tested to higher numbers to achieve the necessary safety factor, but de-rated from the design? No, not according to my mechanical engineer who spent years working for Dana.
Al
