RV.Net Open Roads Forum: Tech Issues: Dometic toilet valave problem
 > Dometic toilet valave problem
Dusty R
Charlotte Michigan 48813
Posted: 04/12/22 05:55am Link  |  Quote  |  Print  |  Notify Moderator
We had the valve break in the toilet in our mh, don't remember why/how, but were told that a new valve was not available, so we bought a new toilet. Then found and bought a new valve. So for the last couple of years we have a new RV toilet, still in box, sitting in our garage.
dougrainer
Carrolton, Texas
Posted: 04/12/22 08:27am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
NO. that is not a valve. that's a "T" or to be more precise a :Y: fitting
You just cannot help but being WRONG. That is a Toilet Valve. Doug
dougrainer
Carrolton, Texas
Posted: 04/12/22 08:37am Link  |  Quote  |  Print  |  Notify Moderator
IF the model 310 which is what the Valve listed is for. You push down Slightly to fill and then all the way to open the ball valve and Flush. To the OP, There were 2 screws supplied with the new valve. Those screws are NEEDED to be installed after the original valve is replaced. They keep the valve secured in place as the original plastic clips will not hold the valve securely in place. This style replacement valve should NOT have affected the operation of the ball valve, but if you state that no matter how gently you push down, the ball valve opens, then I would remove the new Water Valve, put vaseline on the end of the stem going inside and then retry. Doug
Posted: 04/12/22 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Lol, you beat me to it!
2017 Heartland Torque T29
dougrainer
Carrolton, Texas
Posted: 04/12/22 10:49am Link  |  Quote  |  Print  |  Notify Moderator
I should have explained the water valve mount screws. When replacing the original valve, they supply 2 screws to secure the valve tightly to the housing. IF you did not install those screws, it is possible that when attempting to gently push the pedal down, the valve is moving rearward slightly and that causes the water valve to not open until you push more firmly, which will open the Ball valve slightly. If you did install the screws and you did NOT fiddle with the Foot lever, then I would think the new valve is defective and you need to replace it. Doug
Mayor30
Pa
Posted: 04/14/22 08:40am Link  |  Quote  |  Print  |  Notify Moderator
OK, that may be the issue. I did not install the screws because the old one did not have screws in it.
dougrainer
Carrolton, Texas
Posted: 04/14/22 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Correct. That is why they supply the screws. Doug
