RV.Net Open Roads Forum: Can inverter and solar CC share the same wiring to battery?
 > Can inverter and solar CC share the same wiring to battery?
ewarnerusa
Helena, Montana
Posted: 04/10/22 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
My batteries are on the tongue of my TT and my inverter and solar controller are in the front pass through storage. Both are wired individually to the batteries with large gauge wiring. My 10-year old janky wiring needs maintenance/replacement. Can I simplify this wire run with a single run of large gauge pos and neg wires and split it inside the pass through storage? I am thinking a 5' run of 1/0 gauge from the batteries to inside the pass through storage area and split from there. Wiring will be fuse-protected.
Thank you.
Aspen Trail 2710BH | 280 watts of solar | 2x 6V GC batteries | 100% LED lighting | 1500W PSW inverter | MicroAir on air con | Yamaha 2400 gen
2oldman
NM
Posted: 04/10/22 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
yes
CA Traveler
The Western States
Posted: 04/10/22 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
yes
2014 Grand Cherokee Overland
Bob
BFL13
Victoria, BC
Posted: 04/10/22 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
You can run the solar controller output wires to the inverter inputs no split
I do not know if this is valid, but I would always make sure the inverter is on the batt first and has done it's big spark so the big spark is not at the controller when you have the batt out
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
KD4UPL
Swoope, VA
Posted: 04/10/22 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Same set of wires is just fine. In fact, it will help lessen voltage drop when using the inverter and getting solar production.
What size inverter? 1/0 may be too small for a large inverter.
ewarnerusa
Helena, Montana
Posted: 04/11/22 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the responses, this gives me hope for a cleaner upgrade. What kind of tactics do people use for protecting the wiring from the elements between trailer and battery? Thanks
LittleBill
Scranton, PA USA
Posted: 04/11/22 08:13am Link  |  Quote  |  Print  |  Notify Moderator
loom
ewarnerusa
Helena, Montana
Posted: 05/09/22 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
The maintenance project is going well. The connections have tidied up nicely. I know that I have some wire loops that add some unnecessary length/resistance to things, but I am OK with it at this point. I like how the loom worked out.
* This post was last edited 05/09/22 04:26pm by ewarnerusa *   View edit history
