Brownleaf
Durham
Does my motorhome need to be level regrding the refrigerator if it is not being used? Doug
IAMICHABOD
Sunny So Cal
NOPE
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Southern California :(
No but many of us start the fridge a couple of days before we leave, so leveling at home or in storage is necessary.
MFL
Midwest
No, as long as not being used, means shut off.
Brownleaf
Durham
Great, thanks,Doug
SDcampowneroperator
South Dakota
Modern absorption reffigerators tolerate 3 degree side to side, 7degree front to rear off level for extended times without harm. If you can walk in the unit without troubles, your fridge is fine.
There was a time when perfectly level was critical, no more.
opnspaces
San Diego Ca
True for a running refrigerator. But for this question the refrigerator is turned off. If the refrigerator is off it does not need to be stored level
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
SDcampowneroperator wrote: Modern absorption reffigerators tolerate 3 degree side to side, 7degree front to rear off level for extended times without harm. If you can walk in the unit without troubles, your fridge is fine.
OP
^This, for when operating/in use. I've seen 3&6 deg as published limits before.
Remember this is with respect to how the fridge is oriented, not the camper.
Reisender
NA
If it’s one of the new 12 volt compressor fridges it doesn’t matter if it’s running or off.
Brownleaf
Durham
Its a 2004 absorption type. Doug
