pasusan
Northernmost PA
SDcampowneroperator wrote: Modern absorption reffigerators tolerate 3 degree side to side, 7degree front to rear off level for extended times without harm. If you can walk in the unit without troubles, your fridge is fine.
There was a time when perfectly level was critical, no more.
Well, what does "modern" mean? What's the cutoff year that makes it not so critical?
IMWTK
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben
2004 Roadtrek 170 for quick getaways
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub for longer trips
Trip Pics
TurnThePage
North ID
My 2004 travel trailer manual states 3 degrees side to side and 6 front to rear.
2015 Ram 1500
2004 Pioneer 18T6
Brownleaf wrote: Does my motorhome need to be level regrding the refrigerator if it is not being used? Doug
Not in use, shut off? It absolutely doesn't need to be level or even close to level. You could store it on it's side of you want to...
time2roll
The old fridges with a pilot flame seemed more sensitive than the modern 2-way fridges of today that are quite tolerant.
For storage or non-use as long as it is somewhat upright all will be fine.
675w Solar pictures back up
JIMNLIN
Oklahoma
pasusan wrote: SDcampowneroperator wrote: Modern absorption reffigerators tolerate 3 degree side to side, 7degree front to rear off level for extended times without harm. If you can walk in the unit without troubles, your fridge is fine.
IMWTK ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Some time in the 1987-'88 era.
I parked my then new 1984 Aljo 5th wheel trailer beside my barn on limestone crusher run. The barn protected the trailer from the sun however north/south and east west was not level. After 5 years or the Dometic fridge quit cooling (strong ammonia odor). Hole burnt in the tube caused by operating quite a bit out of level.
Replaced the old Dometic with a new one which came with the new 3 degree side to side operation.
