RV.Net Open Roads Forum: Travel Trailers: Putty or butyl tape?
 > Putty or butyl tape?
penguin149
Bowling Green, KY USA
Posted: 04/13/22 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Found a leak around my outside kitchen compartment door. Planning to remove the door, check for any damage and reinstall the door. Should I use putty tape or butyl tape around the door frame and TT side? Thinking the putty tape would compress and spread, allowing me to trim the part that oozes out. Butyl tape is stickier but wouldn’t squish like the putty tape. Can’t decide which is better?!
2014 Nissan Titan 5.6L V8 4WD - 2019 Keystone Bullet 243BHS
MFL
Midwest
Posted: 04/13/22 07:37am Link  |  Quote  |  Print  |  Notify Moderator
I would go by what I find, after removing the door. JMO, but of the two types tape, I'd use the putty tape. It compresses easily, and it is easy to trim the excess. If you want to purchase tape, before removal of door, get both, they're not expensive.
Jerry
2112
Posted: 04/13/22 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I used ProFlex RV sealant.
I put blue painters tape on the wall around the frame leaving about an 1/8" space before I removed the hatch frame. Applied a generous amount of ProFlex between the tape and opening and reinstalled the hatch. Once secured I cleaned the excess with acetone damp rags. Then I removed the tape and gave it one final damp rag wipe to remove the edge the tape left.
Using the painters tape helps cleaning the excess and leaves a real nice, clean appearance.
2013 KZ Durango 2857
BobsYourUncle
Calgary Alberta Canada
Posted: 04/13/22 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Definitely use the butyl tape. Putty tape is cheap and will not last. It will dry out, crack and cause a leak. It is no good for anything.
Use pure butyl tape not a putty butyl blend. It is the most expensive of the 3, but also the best choice. It is a bit more firm, but it will compress. Super sticky but that is what you want. Tighten the screws slowly and evenly, preferably when it is warmer as opposed to a cold day. The excess that oozes out can be easily trimmed and removed with a plastic putty knife. Don't use anything metal.
If it continues to squish out a bit over time, just trim it again. The butyl will remain soft and pliable for years to come, and will keep a good solid seal, unlike that cheap putty junk.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Cambria, California area
Posted: 04/13/22 08:23am Link  |  Quote  |  Print  |  Notify Moderator
I’ve had putty tape dry out too.
aftermath
Washington State
Posted: 04/13/22 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Wow, pretty strong statements here. I like working with the putty tape better. I picked up some butyl tape by mistake once and found it difficult to work with. Went back to the trailer supply store and got good information about the benefits and advantages of both types. For my application, on both my trailer and older tent trailer, the putty was actually better.
I do like the advice to "use what was there" before. I can't remember what the guy told me but it had to do with possible staining and black streaks on fiberglass siding. Again, talk to someone in the know.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Huntindog
Phoenix AZ
Posted: 04/13/22 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Butyl is far superior to putty.
I have had the pleasure of removing dried up cracked leak prone putty more than once, Once butyl is used, it is no longer going to be a problem.
There is a trick to working with it. Keep it in the refridgerator.
I hve a spare fridge for my butyl and other non food items that are better kept cold
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
JBarca
Radnor, Ohio, USA
Posted: 04/13/22 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I have some info that may help you make a decision. I have dealt with a great number of putty tape failures, I restore older campers in the 10 to 15 year range so far. I'm now on my 15th camper rot repair so I have seen first hand the damage from failed putty tape. Siding leaks can be as bad, and in many some cases, worse then roof leaks as there are so many holes in the siding.
This is what a putty tape failure looks like. This was a 13 year old camper at the time of the pics. This is a front window but cargo doors, corner moldings, entry doors or any siding leak failure looks the same when putty tape gets older. It did not take 13 years to get to the stage, the leak started years before.
Putty tape is easy to trim, that is a fact. They alter the sealing compound to make it trim easier on purpose, the side effect is less performance over time.
What you are seeing in these pics is when the putty tape shrinks. And it does shrink, and the UV from the sun accelerates it. When the tape shrinks, it will split in the middle or pull away/separate from the siding or the cargo door flange etc. That starts a leak path. Slowly over time the leak path keeps getting bigger, you can see the water and dirt staining in the putty tape. The tape lifted that is how the dirt was driven into the joint. When the leak path gets long enough, water enters the wall cavities and it is down hill from there.
Close ups
Here is a slide flange removed on a 6 year old camper where the same putty tape failure had started. You can see how the putty tape tears apart when you remove the flange. I caught this leak path just in time before it leaked inside.
Commercial steel building butyl tape is different then putty tape. When you are putting up a million dollar building you do not want leaks in 3 to 5 years like can happen on putty tape. You want 20 year plus quality sealing tape.
I use the GSSI brand, MB-10A part number for their butyl tape. I buy it here. $6.50 a 50 ft roll. for 1/8" thick 1" wide https://www.bestmaterials.com/detail.aspx?ID=19987
I buy it by the case and I go through 3 to 4 cases a year. The case size is cheaper and I have higher odds of it being shipped and not damaged. If you do not want to order it online, then find a building/roof supply place in your area and ask them for their best butyl sealing tape.
I have learned how to trim the butyl, it's not hard to do, but there is a learning curve. Temperature plays a big role in the learning. Too much heat, it is bubble gum, to little and it is harder to trim. A heat gun is your friend, both in removing the old putty tape flange seal and putting new butyl down. Keep the heat gun moving, do not stand still with it. Pending the outside temps will guide you as to use a lot of heat or not much.
In the winter months, my shop is 55F and I need to warm the molding and the butyl to flow on purpose as I tighten the screws, Here is a corner molding. On metal corrugated siding I add extra butyl strips in the valleys of the siding and I fully line the molding. As I tighten the screws, the butyl will ozz and I want it to flow everywhere in that corner.
To trim, I use plastic scrapers from Harbor freight to not scratch the siding. I get the right temp and I can push the scraper right up the joint and trim. I add a little heat is I have to, but not much while trimming or it gets too goo'ey
To clean up any stingers, I use Naphtha on a rag and lightly wipe away stringers to create a clean trim.
If you want close to a bullet proof seal, after a day or two if I used Naphtha, I go back with Proflex RV sealant over the top of the exposed butyl. It creates a 2nd seal and keeps any dirt from sticking to the butyl. There are tricks on how to tool out, smooth out Proflex too, it comes out really smooth and you can push it where you want it. Just do not apply in long lengths, 2 to 3 feet and they tool it out. You have to work quick as once it start to set, it will all glob up. Use a wet soapy finger you will not have any on your fingers. Do not apply in hot sun or sun hot siding, it dries too fast on you.
If you plan to keep your camper 5 to 20 years, use the butyl, it's worth it. If you are going to sell the camper in 3 years, well putty tape will get you through that much.
Hope this helps
John
* This post was edited 04/15/22 06:11am by JBarca *
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
Skibane
San Antonio, TX
Posted: 04/13/22 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
^Excellent post, John - Thank you!
BobsYourUncle
Posted: 04/13/22 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Great write-up John. Excellent! [emoticon]
Nice to see someone knowledgeable post good sound info with pics to support it.
If anyone cares to see another prime example of putty tape failure and disaster, have a look at my RV Rebuild website. The entire thing was "sealed" with putty tape, and the entire thing failed, resulting in the rotten old carcass I rebuilt.
