RV.Net Open Roads Forum: Fifth-Wheels: Landing Gear stoped working
 > Landing Gear stoped working
Gray Fox
Swansea Ma. USA
Posted: 04/13/22 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking for some HitchHiker friends I HAVE A problem with the landing legs they stopped working. It may be the fuse but were is the fuse box for the legs. It's a 2009 HitchHiker L S .
Gray Fox
2014 F350 4x4 Diesel Lariat
2009 HitchHiker-LS 34.5 RLTG
Always keep moving so you don't seize up.
cummins2014
Utah
Posted: 04/14/22 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Should be on the hot lead or red wire going to the landing gear motor , more than likely 30 amp inline fuse .
padredw
East Texas
Posted: 04/14/22 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Are you familiar with the NwWa Owners Forum? Someone there can surely help you. NuWa Owners Forum
I have a 2007 HitchHiker II but have never had a problem with the landing legs. There are two locations of fuses:
1> under the "nose" of the trailer where the umbilical cord comes into the trailer. There is a "lid" which opens and a cover which must be removed, BUT I do not think there is a fuse for the landing legs there, just running lights, brakes, turn signals, etc.
2> Inside the trailer there is the main fuse block under the cover of the power control center there are both AC breakers and DC fuses.
Gray Fox
Swansea Ma. USA
Posted: 04/14/22 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
I found the fuse Ive been looking for it's in the battery
compartment, an it only had a 25 instead of 30 amp. Thanks for your
help.
