LASilvey
Sacramento, CA
We always store our trailer with the fridge open however we will be switching to an indoor facility and they may shift the units around while in storage. My question is, while there's a hundred ways to keep your door open while the rig is still, does anyone else have this situation and a good way to keep the door open yet not banging open/closed in the event the trailer moves? Thank you!
2005 Arctic Fox
2003 Ford F-250 Diesel
1 Hard working hubby/daddy
2 2-legged babies
1 4-legged baby
Near Bishop, California
Once the fridge dries out...two or three days with the door open...I close mine. No issues.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
nickthehunter
Southgate, MI
All the RV fridges that I have seen have a lock that holds the door ajar and locked into that position. Check the manual.
LASilvey
Sacramento, CA
nickthehunter wrote: All the RV fridges that I have seen have a lock that holds the door ajar and locked into that position. Check the manual.
My door has pins you can extend to keep the door from closing however, they don't keep it from swinging open if the rig moves.
RoyF
Fayetteville Arkansas
I haven't tried this, but maybe get a wooden dowel cut to the right length (2 to 3 feet, maybe). Use mini-bungee cords to attach dowel to wire refrigerator shelf. Repeat for freezer. (Thinking of my refrig, which has wire shelves in both sections.)
evanrem
WI
They make little plastic clips that keep the door ajar yet locked in place. We have been using them for years and the work well.
Boomerweps
Hills of PA
Go to a dollar store and get some pool noodles. They have many uses. Good to let the kids beat each other with, among other uses.
Cut a noodle to desired length, then split it. Push the split over the door or frame edge. Tape it in place if needed, using painters tape to minimize residue when removed.
I’d also use the painters tape to hold the door semi shut in case the RV gets moved.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
IAMICHABOD
Sunny So Cal
Mine came with clips Like These snap on and holds door open and doesn't swing out.
Former El Monte RV Rental
Buying A Rental Class C
2112
LASilvey wrote: My door has pins you can extend to keep the door from closing however, they don't keep it from swinging open if the rig moves. Norcold has a slot in the door jam for the pin to slide into to hold the door slightly open.
2013 KZ Durango 2857
camperfamily
New Jersey
Those blue clips do not stay when moving the trailer. Good luck with them. I'd be looking for another solution. Like the foam and bungie concept.
2011 Cougar 322QBS
2007 Pilgrim 278BHSS (Sold)
2013 F350 CC LB 6.7
2002 F350 CC LB PS (Retired)
B&W Companion Hitch
