RV.Net Open Roads Forum: Class A Motorhomes: Tire size
 > Tire size
Don and Eileen
Here, there, and everywhere (formerly MA)
Posted: 04/14/22 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I am using FMCA's discount tire program to buy four tires for my rear axle on my Allegro Bus. (The ones in front are newer.)
I'd prefer to stick with Michelin, but inventory is problematic.
I've gotten a quote on Continental, but I'm concerned about compatibility.
The front Michelins are Model xze 275/80r 22.5 lrh
The Continentals quoted for me are 295/75 22.5 lrg
My concern is if the Continentals quoted were compatible with Michelin given the difference in size.
Thanks
Don and Eileen
JRscooby
Indepmo
Posted: 04/14/22 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Millions of miles on trucks, and rarely did steer tires match the drives.
Tyler0215
Iowa
Posted: 04/14/22 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
What size are the rears now?
Different size from front to rear will not make a difference.
lryrob9301
Anywhere
Posted: 04/14/22 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
A 295/75R22.5 and a 275/80R22.5 are virtually the same size tire. Approximately a 1/4" difference in width and ride height. The 295/75 is a direct replacement for the 275/80. Go with the Continentals, they are just as good as the Michelins.
wolfe10
Posted: 04/15/22 06:06am Link  |  Quote  |  Print  |  Notify Moderator
As long as all tires on an axle are the same, no problem with different ones on different axles.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
rgatijnet1
Posted: 04/15/22 08:44am Link  |  Quote  |  Print  |  Notify Moderator
There are a few things that you really need to check when changing tire size. One is the diameter. Any change in diameter can affect your speedometer as well as your fuel mileage. If the two tires are within 1/4" it should be no problem.
The second thing is tire spacing between tires with duals. Different tires on different rims have a minimum distance that must be maintained between the tires when mounted. If the tires are too wide/fat, the distance between the set of duals may cause the tires to rub against each other.
A third thing is the load rating. You never want to go to a tire with a load rating below what the manufacturer recommends for your coach. If you go with a higher load rating it may result in a harsher ride.
FloridaRosebud
Melbourne
Posted: 04/15/22 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
As rgatijnet1 says, there could be a slight difference in speedometer reading. I changed my tires from Michelin to Toyos, and now at 60mph on the speedo, I'm actually going 58mph (radar and also a friend driving beside me). Not a big deal.
Al
Don and Eileen
Posted: 04/17/22 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Thank you, all. As it turns out, the Michelins that couldn't be found are due to being discontinued. It's frustrating, to say the least, when you're dealing with a tire shop and they don't know this basic information. I've managed to locate their replacements. Thanks again.
 > Tire size
