RV.Net Open Roads Forum: General RVing Issues: RV sulfur smell
 > RV sulfur smell
kramer45011
Ohio
Posted: 04/15/22 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
The campground we stay at has well water and the smell is terrible. The chlorinate it a couple times of year and it is a little better for a short time but it doesn't last long.
Is there anything we can do on our end to eliminate the odor?
Ed_Gee
Central Oregon coast
Posted: 04/15/22 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Good quality RV water filters would be a good start. ... at least an external city water solid carbon block filter like the Clear2O CRV-2006
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
jdc1
Rescue, Ca
Posted: 04/15/22 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Reverse osmosis.
wildtoad
Blythewood, SC
Posted: 04/15/22 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
One of the reasons we always have full water tank.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Posted: 04/15/22 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
When I full timed I stayed 2 weeks in one park 1 or 2 in another. After my wife died a full tank was at least 3 weeks of water.
NOW: one of the parks (always a 2 week stay) used city water and the city over chlorinated.. Made my morning cuppa taste like it was brewed with diluted clorox. Found if I filled the tank..... Chlorine quickly dissipated. (Water supply Chlorine will do that if not pressurized) So I'd fill the tank when I pulled into that park and again when I pulled out to the 1 week park and not even hook up at the 1 week park.. The night he temps hit 11. I was glad to be "not hooked up" I can tell you.
Summers one of the 2 week parks has "Nasty" (Lots of grit) water. .. Now my filter handles it but .. Why clog the filter when I can tank up before leaving the other park and again when I return.
Sulfur.. My Parent's had high sulfur water on their retirement farm... Letting it set helps..
Filters help as well I've been in parks where I could not drink the water without filters.. Even low end filters worked in some of them.
Reverse Osmosis is the filter of last resort. Most expensive. but most effective as well.. Can (depending on how good) produce near pure water.
Resin Distillery can as well
Cambria, California area
Posted: 04/15/22 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Arrive with a full water tank and two or three Jerry cans in the TV.
kramer45011
Ohio
Posted: 04/15/22 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
We are permanent at this park.
corvettekent
Marysville, WA
Posted: 04/15/22 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
You have wheels on your RV for a reason, move on.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Turnover Ball, Companion Hitch.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
kramer45011
Ohio
Posted: 04/15/22 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Corvette
I asked this question for any helpful advice not for people to be an ass. We like where we are at.
bob213
Fresno, CA
Posted: 04/15/22 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
If you are permanent than a R/O filter for drinking water would work well. A Berkey is a great counter top solution for drinking water. For whole house you might check to see if Culligan or some other water filtration company can give you service by the month or install a permanent system that you can service yourself.
Where I live Culligan does more than "soft water" systems. You will have to see what's available where you live.
 > RV sulfur smell
