RV.Net Open Roads Forum: General RVing Issues: RV sulfur smell
 > RV sulfur smell
fitznj
nj
Posted: 04/16/22 04:58am Link  |  Quote  |  Print  |  Notify Moderator
Try installing a couple of carbon filters in your water line;
It worked for me when I got the sulpher smell. I get my filters
at Home Depot and change them at the start of every season.
Gerry
ItsyRV
Lost on the Blue Ridge Parkway
Posted: 04/16/22 06:09am Link  |  Quote  |  Print  |  Notify Moderator
I would first have the water tested to see how much hydrogen sulfide is in the water. If just an amount that causes the stinkies, many filters will do the trick of removing the smell and some HS2. If at a level approaching unhealthy, a more robust system is needed.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
way2roll
Wilmington NC
Posted: 04/16/22 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the water has high iron content. All the chlorine does is mask the smell. Frankly I'd rather live with the smell than deal with the chlorine. I would suggest a 2 stage filter on the inlet to the RV. One stage a sacrificial particulate filter and the second stage a carbon filter. That should solve the problem. The carbon will remove the chlorine (provided it's actually chlorine and not chloramine - you need catalytic carbon for that).
Something like this:
2 stage filter
If you are drinking the water however, I would opt for an RO. Something small under the sink or a Burkey gravity fed RO.
ryegatevt
New Hampshire
Posted: 04/16/22 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Even in our small Class B we always use bottled water for cooking, coffee and drinking and the CG water for all other uses.
Steve & Bev
2005 Roadtrek 210
Tess, our Sheltie
Near Mammoth, California
Posted: 04/16/22 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn’t be “permanent” anywhere with sulfur smelling water.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
jkwilson
Indiana
Posted: 04/16/22 09:33am Link  |  Quote  |  Print  |  Notify Moderator
2 stage filter
The smell is generated by bacteria that thrive in iron-rich water. The chlorine kills the bacteria, which can, and usually does, eliminate the smell for a significant time. We have had wells with the problem for almost 35 years, and conventional filters are not useful for the sulfur smell, though they will stop the chlorine taste/smell. We have a green sand tank, followed by carbon for all indoor water and then RO after those for drinking water. We still need to shock the well with a couple of gallons of 12% bleach a couple of times a year to control the odor.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Caveman Charlie
Storden, MN
Posted: 04/18/22 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if your campground would do it but, I know they make a machine that sets on top of the well and automatically adds chlorine tablets at a preset period of time.
1993 Cobra Sunrise, 20 foot Travel Trailer.
 > RV sulfur smell
