RV.Net Open Roads Forum: Class A Motorhomes: Laminate flooring install
 > Laminate flooring install
Sarahdove
Palmdale, California
Posted: 04/16/22 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hello Happy Campers,
Has anyone pulled up the flooring including the carpet and replaced it with the laminate planks? We just purchased a used class A and would like to replace the flooring.
Thanks for any input.
Sarah and Nick
rgatijnet1
Posted: 04/16/22 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
I took on the task and the install was a day project. What took longer was that after I had pulled up the old flooring, I put on two coats of polyurethane to protect the floor from moisture and to lock out any odors that were in the sub floor. I used matching quarter round on the edges.
MountainAir05
New Mexico
Posted: 04/16/22 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
We also did it.
Posted: 04/17/22 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Yup.. Now I did a slide. it's not that great with a slide as the "lap" ..well. that's kind of different. had to re-carpet that.
laid a carpet runner (cut lengthwise) down with furring strip on one side so it covered the joint.. Worked well. Looked good. (Cut edge under the strip by the way)
jdc1
Rescue, Ca
Posted: 04/17/22 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Be sure to use a waterproof membrane before laying the planks. I took my carpet from the slide to a carpet place. Picked out a decent carpet, and the cut to fit and finished the edge the way it's suppose to be done. Worth the $300 (including carpet). It just staples in place.
phillyg
SWFL
Posted: 04/17/22 11:23am Link  |  Quote  |  Print  |  Notify Moderator
The only negative I can think of is the planks weigh more than carpet, so if you're close to your max weight it might be a consideration.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Sarahdove
Posted: 04/18/22 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your response. :-)
Sarah and Nick & our 2 Golden Retrievers and 2 Boston Terriers
'06 Fleetwood Bounder 35E
2015 Fiat (toad)
"No matter how much money you have or how few possessions, having a dog makes you rich."
Profile has my dog pics
erniee
Weatherford, Texas 76086
Posted: 04/19/22 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Still installing engineered wood
Ernie Ekberg, Prevost Liberty XL Classic
4x4van
California
Posted: 04/19/22 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Be ready to remove about 10,000 staples holding the carpet down!
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
craz z
Montana
Posted: 04/20/22 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Just finished up doing mine on a super C. Luxury vinyl. Laminate is taller and not waterproof. both are WAAAAYYYY heavier then the cheap garbage carpet and thinner then paper sheet vinyl they installed.
Carpet and vinyl is easy to get rid of and there are definitely alot of staples THAT MUST BE REMOVED.
If you decide on LVP Luxury vinyl plank here are a few tips.
1. Groove out. on the side and the rear. This stuff must be installed at an angle and then pushed down. YOU CAN NOT PULL IT LIKE LAMINATE. (more on this later)
2. When installing the skinny end to end Hammer the joints to lock them in. (use a rubber hammer or scrap piece on top so you don't damage your joints.
3. Starters. when starting. I got lucky by using the slide as a guide and it worked perfectly going across the room. However there are corners that need to be filled in or transitioning in a new room. use a scrap put the tongue in and throw a screw in it so it can't move. dont use the spacers they won't work. This stuff is so precise close enough will not work and pulling it will destroy it. Its either locked in or its not.
4. If you don't have a vibrating multitool get one. They are a must for undercutting transitions to other rooms. use a scrap and zip out the material so the floor has a seamless look. Dont try to measure, it will look awful and cuts will take hours.
5. Transitions and undercuts. well now what do I do? you said it must be at an angle to lock it in. This happens when you get to the finishing side of the project. This is the most important lesson of all. You are under a doorway perfect under cut and now need to lock it in. Take a mini hand planer or what i used was a wood chisel and knife off the groove's lip. This will now let you pull it like laminate with little effort to lock it in. Since its under a door and locked in next to a wall. the lock isn't that important as you just removed it. if you feel compelled for leaks sake add some glue in the groove to waterproof it.
6. Don't be lazy anything in the way take it out label it and put it back. I'm talking about vents and trim coverings go under them not around them. you can only hide so much with quarter round.
7. It may not be correct but I did it anyway. The number one reason to choose LVP over laminate or stickon is its not supposed to expand and contract as violently with extreme temperature changes that are in rvs.
I did not gap anything. tight as possible around walls shower radius's toilets you name it. that gap is where water will migrate too and rot the subfloor. If a gap happens caulk it. like around the toilet flanges oh yeah remove the toilet don't go around it.
8. Templates. take the time and do it right. I had so many weird cuts in a tiny mid bath I spent a whole day in a 3x3 foot space.
paper is your friend cardboard is your next best friend. cut your shapes perfectly before transferring to LVP. I even deployed one of those contour gauges to help with shapes. RV's love to round everything nothing is straight. If you can under cut that's the fastest templates are a must for certain spots.
9. I almost forgot. Tapping blocks. Don't use them If you do use the full square edge. Better yet take a scrap insert the tongue and bang on it. Tapping blocks are better for laminate not for LVP.
I've done several laminate projects over the years and this is nothing like it. I spent alot of time on youtube and removing and replacing pieces until I figured out that this is nothing like laminate or even hardwood install.
My last rv I did the stick on and would never ever use it again. looks good until a season or two down the road and the expansion and contraction on stickon is so extreme it looks terrible a year or 2 down the road.
No matter what you choose I firmly believe that flooring is the most dramatic upgrade you can do for the least amount of money. I was forced to do LVP as the cold winter literally split the wafer thin sheet vinyl everywhere. Exposing raw wood subfloor. and the amount of dirt under the carpet was enough to fill a shopvac.
* This post was edited 04/20/22 11:47am by craz z *
