RV.Net Open Roads Forum: Class A Motorhomes: Steps
sssooo
Ohio
Posted: 04/16/22 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
I just stopped for the nite and my steps won’t come out I checks the plug it’s ok
I have a 2018 Fleetwood Bounder 36”
* This post was edited 04/16/22 06:40pm by sssooo *
MountainAir05
New Mexico
Posted: 04/16/22 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
door switch at door or magnetic door switch on the screen. Do not stick your hand in there. Would cut it off.
If you can get under from the side try a screw driver or hammer. Jump the door switch and the magnetic switch if that did not work. Maybe a fuse.
sssooo
Ohio
Posted: 04/16/22 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I checked the magnets it not that
Thanks
enblethen
Moses Lake, WA
Posted: 04/16/22 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Blown fuse for control or blown fuse for motor.
Door overide switch on
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
sssooo
Ohio
Posted: 04/16/22 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I looked at my fuses that are in my bathroom they all checked ok ?
craig7h
Branson MO area
Posted: 04/17/22 03:15am Link  |  Quote  |  Print  |  Notify Moderator
I guess my first question is, does the motor have power? Can you hear it try and run when you open or close the door?
If the motor has power and tries to operate, you might what to check this. Could the steps be binding putting pressure on the system which will shut if off. The pivot points on the steps may be dirt and need lube of some type. Have you gotten underneath and looked to see if the motor assembly was still attached to the frame. The reason I asked that was last year my steps stopped working but the motor was running. I looked underneath and the four screws holding the motor assembly had become loose and sheared off.
Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
dougrainer
Carrolton, Texas
Posted: 04/17/22 07:19am Link  |  Quote  |  Print  |  Notify Moderator
The simplest check is also easy. Under the step is an amber light. WATCH the light and have someone OPEN and CLOSE the door with engine running. IF the light goes ON and OFF with the opening and closing, the wiring is OK and the probable failure is the step motor. SAME procedure with engine running and opening and closing the door. Tap(bang) on the step motor with a hammer. IF the step then functions the motor had a dead spot in the armature and needs replaced. It will probably work after you do this but WILL fail again. Doug
Posted: 04/17/22 08:57am Link  |  Quote  |  Print  |  Notify Moderator
Fuses in bathroom may not be proper fuse block
All motor homes have at least 2 fuse blocks
some 3 or more (mine had 4)
Step fuses on my Gasser were in the "Intellect Battery Control Center" box.
sssooo
Ohio
Posted: 04/17/22 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Where is that block ?
Scott
RedRollingRoadblock
Oregon
Posted: 04/17/22 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Should be first compartment to the rear of your entry door. Black box about 10x8 inches. Fuse F3 and F4. https://rvcustomproducts.com/f73-1020
