RV.Net Open Roads Forum: Class A Motorhomes: Steps
enblethen
Moses Lake, WA
Posted: 04/17/22 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Fuses are commonly located adjacent to the battery disconnects. Operating the battery disconnect by helper while you listen for disconnect operation helps in locating it.
Did you test the fuses or just look at them?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dougrainer
Carrolton, Texas
Posted: 04/18/22 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Just curious. I TOLD everyone how to do an easy test for the fuse. Takes 30 seconds. Did you do that? Doug
sssooo
Ohio
Posted: 04/18/22 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I checked the plug underneath the MH and got no power so no lite!
FLHTCI
east coast
Posted: 04/19/22 07:04am Link  |  Quote  |  Print  |  Notify Moderator
This post was very helpful for me.
On a trip to Florida my stairs became erratic, opening and closing as we drove. I pulled the plug and wire tied the stairs up. I replaced the motor once I got to my destination. We stayed for 6 weeks assuming everything was cool, it wasn’t. As we rolled down the road the same thing happened. I pulled the plug and wire tied the stairs again, the motor was hot.
Someone pointed out that it maybe the magnetic sensor.
My apologies for not adding your quote to this post.
2012 Winnebago Itasca Class A Sunstar 30T
2013 Jeep Sahara (JKU)
2012 Harley Davidson FLHTCUTG
2012 Ford F-250
dougrainer
Carrolton, Texas
Posted: 04/19/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
When you find the 20 amp fuse. Install a Auto Reset 20 amp 12 volt circuit breaker. Then you do not have to worry about a fuse blowing, unless you have a direct short, which will cause the CB to not reset. Doug
sssooo
Ohio
Posted: 04/19/22 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the 2fuses but still have no power it the plug under the mo would a bad motor cause it to have no power I am at a lose?
Scott
dougrainer
Carrolton, Texas
Posted: 04/19/22 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Scott
How are you checking for Power? Test light or Multimeter?
RED should have 12 volts
Yellow 12 volts when engine running
White 12 volts when switch is on
Brown is a ground from door magnetic switch
Motor CANNOT cause a Power problem.
Last, the Odds of losing 12 volts on all 3 (Red/yellow/White) at the same time is statically extreme. They each have their own fuse supply(3 fuses). Doug
sssooo
Ohio
Posted: 04/19/22 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Test lite
Are the fuses on that board?
enblethen
Moses Lake, WA
Posted: 04/19/22 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Have you verified the two ground connections at the step?
Did you locate the fuses at or near the battery control center?
sssooo
Ohio
Posted: 04/19/22 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Would that be f22 or f 13?
