RV.Net Open Roads Forum: Tow Vehicles: GM buying back 6.6L Duramax
Search only in Tow Vehicles
 > GM buying back 6.6L Duramax
BenK
SF BayArea
Posted: 04/16/22 11:41pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone know why GM is buying back late model 6.6L Duramax's ?
-Ben Picture of my rig
bucky
Raleigh metro
Posted: 04/17/22 04:19am Link  |  Quote  |  Print  |  Notify Moderator
Duramax buy back clicky
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Tvov
CT
Posted: 04/17/22 05:42am Link  |  Quote  |  Print  |  Notify Moderator
I didn't see in that link what the actual problem(s) is with the motor.
2021 F150 2.7
Sjm9911
New Jersey
Posted: 04/17/22 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Wow, if they are buying them back that probably means no fix to the problem. Not good.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Southern California :(
Posted: 04/17/22 07:26am Link  |  Quote  |  Print  |  Notify Moderator
No fix and no new trucks on a GM lot to buy as a replacement.
FishOnOne
The Great State of Texas
Posted: 04/17/22 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I don't understand why GM doesn't simply replace the motor.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
FlatBroke
CO/AZ
Posted: 04/17/22 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Mine is 20 years old I’ll take a do over, please. [emoticon]
Hitch Hiker
"08" 29.5 FKTG LS
Posted: 04/17/22 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like just new trucks. So considering no significant changes to that engine since 2017, must be a quality issue and not an inherent defect. Hopefully limiting the quantity of buybacks.
Hood this doesn’t put a damper on the 500hp+ version promised.
Second Chance
Wherever...
Posted: 04/17/22 08:49am Link  |  Quote  |  Print  |  Notify Moderator
The only thing I can find was on a Duramax forum in comments on a thread. According to that, it seems to be a "heat treatment issue with the block that causes warping and hydrolock"
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
ksss
Eastern Idaho
Posted: 04/17/22 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Rob
Thats what I found as well.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
