RV Newbe
Belle Fourche, South Dakota
Don’t know which model it is . I’ll soon purchase my 1st class A motor home (my son owns it) and need some help….don’t know what length it is…only saw it once from outside and find out it’s basically gutted so will be renovating it….love diy projects so I’m ready to start in May. Recently widowed so this will be a new start for me. Haven’t found much info on the internet so any info will be appreciated. I previously owned a 22 foot Dodge Shasta-don’t know what year it was but I was impressed with how easy it was to work on. Didn’t like it being top heavy so looking forward to driving this class A.
RLS7201
Dodge didn't make class A motorhomes. Could it be your talking about a Winnebago on a Dodge chassis? Back in that era the Dodge chassis had 413, 413P 440 & 440P engines. The P engines were truck engines with a high mount water pump. The standard B block water pump had a 4 bolt mount ver. a 5 bolt mount for the P engine. Some of those old beasts had od sized tiers that were hard to find. 16.5" I think.........
Anticipate about 4 MPG..........
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Owens River area
Welcome! I’d start with maintenance on the outside…roof and sides…unless you have covered storage.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
RV Newbe
Ty for clarifying that for me….didn’t know that….
MountainAir05
New Mexico
I would check for the wheels and tires first. Had a 75 and they had the 16.5 and could no long find tires. Nothing larger would fit the axles.
Good luck.
toedtoes
California
Yes, there are Dodge class As out there from the 70s and earlier.
Class C of that era will most likely be a 440 or a 360.
If it's a class C, it will be on a B300 sportsman van chassis. If it's a class A it will be a MB300 chassis.
For tires, the only 16.5 tire still being manufactured with the rating needed for a motorhome is the Firestone Transforce. Most likely you will need to order them online as most stick and brick tire shops don't have them in their ordering system.
You may be able to find 17 wheels that will fit, but they are not made anymore so you have to check salvage yards, etc. And you have to make sure the bolt pattern is correct.
It's a very long read, but you can find information on this thread
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
toedtoes
California
And if the engine is running well and you replace ALL the rubber fuel lines, you will get about 7-10 mph. If you get less than 7mph on a flat road, you have a fuel leak (which is very common as many have never had their fuel lines replaced).
femailyetti
South of Disney World
Post pictures please.
donkeydew
OR
it is probably 1978 champion motorhome on a dodge chassis
