RV.Net Open Roads Forum: Class A Motorhomes: 2003 Newmar Dutch star help #2
 > 2003 Newmar Dutch star help #2
David0725
Posted: 04/20/22 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
the 7500 0nan Gen set some times starts then shuts off Like its not getting fuel?
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
Ava
Vancouver Island. BC Canada
Posted: 04/20/22 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming you have a diesel generator, the fuel comes from a fitting a few inches up from the bottom of the coach fuel tank. If your fuel tank is low it will keep the generator from starting. Hopefully nothing more serious.
ferndaleflyer
everywhere
Posted: 04/21/22 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Or the fuel filter which is easy to change. Underside of generator will be a sliding latch which will expose the fuel filter. I think I paid $16 or $17 for one a couple of weeks ago. Youtube is your friend as is Amazon
dougrainer
Carrolton, Texas
Posted: 04/21/22 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a fuel supply problem, then when it stops and you attempt to restart, it will have to crank for at least 5 to 10 seconds minimum to supply fuel. If it starts right back up, you have another problem not related to fuel supply. Doug
PS, check your Oil level.
Bikeboy57
Inverness, FL
Posted: 04/23/22 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Excellent quick check on fuel issue Doug.
When it stops, does it stumble as it stops OR is a clean stop like pressing the off switch? Stumble is fuel related. Clean stop is control related.
Richard and Rhonda
1999 Newell
Subaru Outback toad
wallynm
Los Alamos NM
Posted: 04/24/22 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
We had a problem that was caused by a kink in the fuel line that was caused when the generator tray was pulled out and pushed in. The link broke the line slightly and allowed air to enter the fuel line. Www rerouted the fuel line and the problem went away the air in the fuel line caused the generator to stop. Took us months to figure it out. Check the entire fuel line to the generator. GOOD LUCK
* This post was edited 04/26/22 09:13pm by wallynm *
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
