RV.Net Open Roads Forum: Class A Motorhomes: 2003 Newmar Dutch star shift pad
 > 2003 Newmar Dutch star shift pad
David0725
Posted: 04/20/22 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
The shift pad stays on number 6 front the start I seems to be shifting just fine. I was just wondering if it was in some Mode that keeps it there?
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
Ava
Vancouver Island. BC Canada
Posted: 04/20/22 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you have an Allison transmission, the pad has two numbers. The one on the left is the gear it is heading to and the number on the right is the gear you are currently in. The mode button can have different uses on different transmissions. My mode button makes mine shift up at a lower rpm.
William B
On the road
Posted: 04/21/22 04:31am Link  |  Quote  |  Print  |  Notify Moderator
Some Allison pads only have one number, and it sounds like yours is one of them.
Full timing since 2004
2007 Holiday Rambler Navigator 45' DD Series 60
2019 Dodge Ram 1500 Limited
Our Blog
wolfe10
Posted: 04/21/22 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Yes, let us know if you have the one window shift pad or two.
ASSUMING it is a one window, 6 is exactly the same as "D" in your car. It is the gear toward which the transmission will shift as you accelerate.
The mode button is entirely separate and changes when the transmission will shift up/down at higher throttle positions.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
dougrainer
Carrolton, Texas
Posted: 04/21/22 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Download this guide. Doug
https://cdn.mpparts.com/pdfs/Trans%20Codes.pdf
