Robbies grandpa
Central Florida
Next month we are traveling from Florida to Tennessee using I-75. I was thinking of timing our drive through Atlanta early on a Saturday or a Sunday morning. Is one better than the other?
ken56
Tennessee
It's roll the dice with that. Be patient is all and hope for the best. I refuse to go through ATL any more. I go around on 441. Yes. it's slower and through small towns but so much less stressful.
Horsedoc
Dixie --- N. Georgia
Sunday after daylight. Watch which lanes you are using - they end abruptly sometimes
MetalGator
I've done Atlanta multiple times now in the motorhome. Every time has been during a weekend. Sometimes in the morning and sometimes in the afternoon. The key for me is to always stay in the middle lanes as there are left and right exit lanes you can get stuck in. I have had no issues going straight through on I-75 and in most cases it is much faster than going around.
2018 Miramar 35.3
2005 Dodge Ram Quad Cab 1500
3 fur kids (Monty, Lola and Pinto)
Rainbow bridge (Murphy)
p220sigman
Tallahassee, FL, USA
From my experiences, it really doesn't make a difference whether you go around on 285 or through on 75. Sunday morning early is likely better if you get through before everyone traveling home from somewhere starts through. Likely the earlier in the morning the better. If there is a traffic crash, all bets are off.
bgum
South Louisiana
One piece of advice: Don't do it. Go around.
valhalla360
No paticular place.
Avoid rush hour (which either option appears to do) but otherwise, never really got the panic over going thru Atlanta.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Dave in TN
Middle Tennessee
I've been through Atlanta many times with RV's. Early on Saturday or Sunday morning, you typically will be fine. Honestly, I have more trouble with two other areas along that route. The stretch of I-75 south of Atlanta, near McDonough, nearly always causes me grief. And going through Chattanooga on I-24 can be a nightmare. When planning the timing of your drive, I'd consider getting through not only Atlanta early but also Chattanooga if possible (they are approx 2 hours apart).
Cambria, California area
Went around once based on advice and it worked fine.
bgum
South Louisiana
Atlanta area drivers follow too close and drive too fast for the conditions. They also change lanes too often. I seriously doubt many could pass a driving test. I've been going through Atlanta since the late 60s. It has steadily grown worse and now I refuse that route.
