elargentino
Vancouver WA
Just had the converter stolen while rig was in storage. We had trouble finding a replacement so we just welded in a straight pipe, which works great except the engine check light is on all the time now because the O2 sensors aren't connected. Anyone know how to disable that particular sensor without affecting the other sensory systems on the engine? We don't have emissions checks in WA anymore and I see no reason to replace the converter only to have it stolen again! BTW, the cops do NADA! I hate to pollute but this gig gets expensive (I was quoted close to $2000 to replace the system correctly (if we can find the right part!)
Tom/Barb
Oak Harbor, Wa
remove the Blub
ArchHoagland
Clovis, CA, USA
What did your insurance company say?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
jorbill2or
Full time
You don’t have auto/rv insurance ? That’s what insurance is for and that would be a covered expense in comprehensive. Why have insurance if you don’t let it cover the large expenses?
Bill
JaxDad
Greater Toronto Area
elargentino wrote: Just had the converter stolen while rig was in storage. We had trouble finding a replacement so we just welded in a straight pipe, which works great except the engine check light is on all the time now because the O2 sensors aren't connected.
The issue is not just the light on, without input from the O2 sensors the ECM will go into ‘default’ mode and the air / fuel mixture will be way off (far too rich) what it should be.
Gooma
Iowa
Your engine was designed to run with the converter in place. How much damage are you doing running without it? Hopefully you are smart enough to have insurance, use it to get the converter replaced.
Or put a piece of tape over the light so you don't see it.
RLS7201
JaxDad wrote: elargentino wrote: Just had the converter stolen while rig was in storage. We had trouble finding a replacement so we just welded in a straight pipe, which works great except the engine check light is on all the time now because the O2 sensors aren't connected.
If the O2 sensor to the rear of the converter is the one that's not connected, it only reports to the ECM, if the converter is working or not and had no effect on the tune of the engine. If the O2 sensor forward of the converter is not connected, then you post is correct.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Owens River area
Why the slap at law enforcement? Cuzz your converter was stolen? What do you, Mr. Citizen, want the police to do or do differently?
bgum
South Louisiana
In some jurisdictions the fine is considerably high if cited with tampering or disconnecting a pollution device. Of course if one collects on insurance and doesn't replace the cat it may even out.
RetiredRealtorRick
St. Augustine Beach, FL
https://www.epa.gov › documents › exhsysrepair
Mb8 131991 - US Environmental Protection Agency
Under federal law, catalytic converters may not be removed and replaced with "converter replacement pipes' by any person. The 1990 Clean Air Act Amendments even prohibit private individuals from installing "converter replacement pipes" on their own vehicles.
. . . never confuse education with intelligence
