Globy
Rockies
Thanks again for the recommendations…one last question for all. Of the two routes from Alamosa to Colorado Springs…La Veta Pass or Poncha Pass…which would you feel is less dangerous, easier on the nerves and our old slow heavy RV…all things considered (passing lanes, grade, road conditions, curves, elevation, etc)?
JRscooby
Indepmo
Lwiddis wrote: While I don’t have issues going up or down in my rig, I also don’t mind at all being behind slow RVs. Gives me time to see more scenery and shows you are being careful descending. Gear down and stab, slow way down and release. Drive on and enjoy!
Many people fail to understand same weight, same grade, it it takes a whole lot more brake to hold speed between 50 and 40 than it takes to hold between 40 and 30. Longer and harder stabs, with shorter time between can get things exciting
BB_TX
McKinney, Texas
Globy wrote: Thanks again for the recommendations…one last question for all. Of the two routes from Alamosa to Colorado Springs…La Veta Pass or Poncha Pass…which would you feel is less dangerous, easier on the nerves and our old slow heavy RV…all things considered (passing lanes, grade, road conditions, curves, elevation, etc)?
I would chose the Poncha Pass route with your RV. Mainly due to easier grade that way for your “old heavy RV”. Easier climb going up and less braking going down makes it easier on the nerves and RV. But still watch your speed going down.
Thom02099
Loveland,CO
H E R E - Poncha Pass is a link to driving over Poncha Pass (a few minutes into the video) and H E R E - La Veta Pass is a link to driving over La Veta Pass.
Personally I think the views are better going northbound over Poncha Pass than eastbound over La Veta Pass but that's just me.
last
edited 04/24/22 09:36pm by Thom02099 *
View edit history
2007 GMC Sierra SLE 3500HD Dually
2016 Coachmen Catalina Legacy Edition 243RBS
2007 Keystone Outback 25RSS - R.I.P.
BarabooBob
Baraboo, WI
I went over La Veta Pass last week with my TT. It is probably the most gradual climb of any of the passes we encountered on this trip. It tops out at 9,426'. There are passing lanes going both directions so people can pass whenever they want.
Make sure to shift down on the way up and down. I would not be surprised to hear that you go up and down in second gear doing 35 mph. Keep the gears low and let the engine work going up and down.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
donkeydew
OR
if your husband is uncomfortable with your rig or his driving don't do it.
he knows what each are capable of.
think of the kids if nothing else there is a lot of other place to explore
4runnerguy
Glenwood Springs, CO
Neither Poncha Pass nor La Veta Pass have the extended downhill like I-17 south of Flagstaff. That 20 mile drop down to Camp Verde is amazingly long.
I wouldn't worry about climbing either of those passes as both have quite gentle approaches all the way to the summit.
I would personally use Poncha Pass. One advantage it has over La Veta Pass is that the speed limit on the downhill side is 50 mph compared to 65 on La Veta Pass. It's easier to hold speed when you're starting from a lower speed to begin with. Once you're past Salida, the road in the canyon also has a lot of sections with lower speeds (50 mph) so much easier on your vehicle.
Thom's advises to use CO 115 does cut off the mileage through Pueblo but do be ready for a lot of traffic on CO 115 through Colorado Springs as you approach I-25. It does save quite a bit of mileage and interstate driving. Do make sure you're in the left lane as you approach I-25.
Try not to be on I-25 between Colorado Springs and Denver at rush hour. Amazing how many people communte between these two areas every day.
Ken & Allison
2 Camping Cats (1 diabetic)
1996 4Runner, TRD Supercharger, Edelbrock headers
2007 Fleetwood Arcadia, Honda EU2000i
4 mountain bikes, 1 canoe, 4 tents, 8 sleeping bags, 2 backpacks
(You get the idea!)
BackOfThePack
Fort Worth
La Veta was more exciting in a Class A at high summer circa 1976. The Dodge-powered rigs made it over, the Fords & Chebbies coughed to a halt.
Plenty of big truck wreckers sitting alongside to get them over.
2004 555 CTD QC LB NV-5600
1990 35’ Silver Streak
