MissouriCamper
Plattsburg, MO, USA
I'm planning on removing my dinette and replacing it with a recpro 70" jack knife sofa. Anyone that has done this did you secure the sofa to the floor or did you just let it sit as is. There is something about using L brackets on their site but the information they provide is extremely sketchy to the point of being invisible.
Mike & Shirley
2009 F250 SD Supercab 6.4 w/3.55
Ford Brake Control, Equalizer
2018 Flagstaff Microlite 25FKS
Owens River area
An unsecured sofa wouldn’t be wise IMO…not that it needs to be overdone however.
joelc
Cedar Point, NC
I have a 5er and both the reclining chairs and sofa that is in a slide just sit there. When I am on the road and close the slides the sofa and chairs are penned in and can't move.
valhalla360
No paticular place.
The ones we have had always just sat there with nothing holding them in place.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
stripit
Prescott
We just removed the sofa from our rig and it was held down to the wooden flooring with lag bolts. Then there were large bolts for the seat belts that went into steel framing.I would use some way to secure the unit to the floor.
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
dieseltruckdriver
Black Hills of SD
We pulled the jackknife sofa out of ours and replaced it with a dual reclining loveseat about 4 years ago and it's not fastened down. The original one wasn't either. No problems yet.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
rhagfo
Portland, OR
stripit wrote: We just removed the sofa from our rig and it was held down to the wooden flooring with lag bolts. Then there were large bolts for the seat belts that went into steel framing.I would use some way to secure the unit to the floor.
OP is asking about a 5th wheel, only our kitchen table is secured, chairs, futon, recliner all just sit there..
ReneeG
Meridian, Idaho
rhagfo wrote: stripit wrote: We just removed the sofa from our rig and it was held down to the wooden flooring with lag bolts. Then there were large bolts for the seat belts that went into steel framing.I would use some way to secure the unit to the floor.
Same with our FW. Only the table is screwed down.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
jdc1
Rescue, Ca
A jacknife sofa is not the same as a regular sofa or recliner. They are top heavy. They need to be bolted in place. The plywood subfloor in slides is 1". Use lag bolts. The framing under the plywood is usually 1" also, so, if you penetrate the plywood, do so no more than 3/4".
MissouriCamper
Plattsburg, MO, USA
jdc1 wrote: A jacknife sofa is not the same as a regular sofa or recliner. They are top heavy. They need to be bolted in place. The plywood subfloor in slides is 1". Use lag bolts. The framing under the plywood is usually 1" also, so, if you penetrate the plywood, do so no more than 3/4".
Thank you, very informative and useful information. I appreciate you along with the others, taking the time to respond to my post.
