RV.Net Open Roads Forum: Travel Trailers: Norcold Fridge Question
 > Norcold Fridge Question
mconnell
Kansas
Posted: 04/24/22 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all,
Matt here, and I am new to the RV life (but loving it so far!). I have a 2018 StarCraft with Norcold fridges. Up to this point, it has been working fine. This week, I went to kick it on (Gas) and the lights were real dim (hardly showing), and nothing. At that point, I knew I needed a new battery, so I replaced it. I hooked it to shore power, same issue, even with a new battery.
I let it sit for a few hours, turned it to gas and the lights appeared correct, but the gas light went solid quickly, even on auto, the lights were normal. Then the issue was, it would not cool. Lights are not, but nothing seems to be happening.
Any ideas? Appreciate any help or suggestions. Taking it will cost $150 hour, so I am hoping to avoid that [emoticon]
Thank you!!
~Matt
larry cad
ohio
Posted: 04/25/22 05:24am Link  |  Quote  |  Print  |  Notify Moderator
What model Norcold fridge du you have?
Our Travel Blog
MFL
Midwest
Posted: 04/25/22 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum!
Are you saying it wont work on both gas or electric? You do realize that it can take a long time to reach proper cooling (such as overnight)? You said it has been working fine. Was that just recently, or last season? If it hasn't been used for a while, it can take some time for the propane to fill the lines.
Jerry
The more info you give, the more accurate the responses will be.
Owens River area
Posted: 04/25/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Unless you treat your new battery well (if not Lithium by recharging daily and if unsealed checking the water level) it will quickly become an "old" battery needing replacement. Suggest you read about RV battery basics.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mconnell
Kansas
Posted: 04/25/22 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Hi, Larry and MFL,
I have a Norcold N611RT. I am going to let it sit till tomorrow (more than 48 hours sitting) and try again, perhaps I went too fast. Any other ideas would be appreciated!
MFL
Midwest
Posted: 04/25/22 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Put a glass of water in fridge, to test temp, using a thermometer, after leaving the fridge operating till tomorrow.
To get propane flowing, after extended shut down, it normally helps to light a stove burner first.
Jerry
Caveman Charlie
Storden, MN
Posted: 04/25/22 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure the gas is lighting ? On my camper I can go outside open the outer door where the fridge is and by sliding open a little cover I can see the flame.
Also, (Though this is no related to the fridge), why did your battery go dead ? Is it charging up correctly when you are plugged in ?
1993 Cobra Sunrise, 20 foot Travel Trailer.
mconnell
Kansas
Posted: 04/26/22 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Thank you, Jerry, I'll give that a shot too. I'll run the stove for a bit.
Caveman - I am not sure the gas is lighting, I don't hear anything, I plan to try it again (maybe today or tomorrow... when it warms up a little) and I'll see if I can see/hear it. As for the battery, it was original (4-5 years old) and was not holding a good charge.
larry cad
ohio
Posted: 04/26/22 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what the condition of the light is. If it is solid red, you may have a gas valve lockout. Anyway, your manual has a trouble shooting section that relies on you reading the exact status of light or lights. Read up on that and give us some more information.
You may have low voltage, gas valve lockout, a blown fuse, or a number of other problems.
Thom02099
Loveland,CO
Posted: 04/26/22 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Good suggestion from Caveman. At elevation, I usually have to open the back of the fridge and as suggested, move the little cover that exposes the pilot light. If you've turned on your stove and gotten it to light, you could also try to manually light the pilot light for the fridge.
I'm presuming you're not at elevation over 5000 feet? I'm right at 5000 feet and my Norcold lights fine, but at 9000 feet I have to manually light it.
2007 GMC Sierra SLE 3500HD Dually
2016 Coachmen Catalina Legacy Edition 243RBS
2007 Keystone Outback 25RSS - R.I.P.
