Gjac
Milford, CT
Has anyone purchased or looked at a small Class C like the Cross Trail CBT on the transit chassis and compared it to one on the 350 chassis? Does the front cab area have more room than the 350 floor your feet especially on the passenger side? Is there an increase in fuel economy? At first glance it is slightly shorter, narrower and lower in height than a C on a 350 which is what I would be looking for. Does it handle any better than the 350 without a bunch of suspension add ons?
bobndot
Our next rv will be a LTV on a Transit.
I think the Transit has a little less GVWR , you would need to watch what you pack into it regarding payload. Just double check on those numbers to verify.
People we know had one , it gets about 16 mpg. It did not need any aftermarket on-ons for suspension flaws. It drives more like a van/suv than a class C.
The cab footwell on the pass side seemed to have more room but the overall cab space is smaller than a 350 cutaway. When you need to go from the cab to the rear of the rv, its a tighter squeeze between the seats. It seemed easier to have a conversation while driving bc it is narrower , so you sit closer to be able to hear voices and it seems to be a more quiet cab.
If i remember correctly the Transit offered at least a pass side swivel seat. The drivers side swivel might be floorplan contingent.
It also seems closer to the ground, it was easier to get into the cab.
Thinking out loud :
What i do not know is the ground clearance or rear overhang situation. That is what i still need to explore bc i do use my rv on dirt roads off grid. I also think i will lose my hydraulic jacks for leveling. But, my new rv will have a comp fridge. Should not be an issue. I think.
bobndot
Regarding the Cross Trail, or other similar floorplan.
It appears as that corner bed is tight. We need at least a full queen 60x80 or short queen 60x74 would work but not a double bed of 54”.
I would also check the shower dimensions. Even though they advertise 24x30, Some are only really 20-21” interior width x 28”. If you drop the soap, you’re not picking it up unless you get out of the shower.
Those curved backrests on that type of dinette are not very comfortable. Its ok for a quick bite to eat but as a tv watching or sitting longer term, we had to redesign ours.
We removed the cushions and replaced them with reclining gaming chairs from Amazon. We used screws and pipe clamps to secure the round bases of the new chairs into the OEM plywood. Now we have nice comfy chairs to sit in during cold or inclement days.
We kept the cushions for resale purposes.
One other thing to be aware of in this type of floorplan are huge skylights in the front portion of the coach. In the past, many owners have complained that the AC units can't keep up with the heat that’s produced by the skylight on hot days. Just something to look into.
Desert Captain
Payson
Ah, the myth that will not die... ![doh [emoticon]](http://www.rv.net/sharedcontent/cfb/images/doh.gif)
"Does it handle any better than the 350 without a bunch of suspension add ons? "
I have owned our E-350 24' Class C for 7.5 years and 70,000+ miles. it has 3,363# of payload, 420# of torque, 305 HP, 7' of headroom throughout and it rides and handles just fine with no, none, zip, nada after market suspension add ons. Proper alignment and psi for the load it carries are all you will ever need.
As to your original question I think you can expect a lot less payload, towing capacity, storage, headroom etc. in exchange for improved mileage but then every RV is a series of compromises. Go with what will work best for your intended usage.
theoldwizard1
SE MI
Newer Transits can be upgraded to swivel seat since they moved the parking brake.
IMHO, Transits need a wider rear axle. The factory passenger van comes standard with a rear A/C unit. Does that mean you have to run the roof A/C on a Class C while you are on the road ?
rjstractor
Maple Valley, WA
theoldwizard1 wrote: Newer Transits can be upgraded to swivel seat since they moved the parking brake.
Since a class C is built on a cab and chassis and not a passenger van, the class C probably doesn't have rear A/C while driving.
Gjac
Milford, CT
bobndot wrote: Our next rv will be a LTV on a Transit.
Thinking out loud :
What i do not know is the ground clearance or rear overhang situation. That is what i still need to explore bc i do use my rv on dirt roads off grid. I also think i will lose my hydraulic jacks for leveling. But, my new rv will have a comp fridge. Should not be an issue. I think. Good info Bob, I did not realize they would get 16 MPG That is a significant increase over the 350. As far as the rear overhang the WB to length ratio is 55%. A 24 ft 3 in C on a 350 with a WB of 158 ins would also be 55%. I would miss the hyd jacks also but as some have said with short C's you can jockey the MH in the camp site until it is level. I like the large rear storage bay in the rear, don't like the small corner bed but I guess I could sleep in the upper over cab bed like Phil does. Every thing is a trade off. I did not see an overhead window on the cross trail. The cross trek has one along with other B plus's. The cross trail has an small cab with a single overhead bed.
edited 04/26/22 07:57pm by Gjac *
bobndot
Gjac, I'm not sure how much weight the rear axle can support.
you would have to be careful loading-up that big 'easy to overpack' rear storage compartment.
Yes, I won't miss the jacks either Leveling at a campsite is real easy now. I installed a small set of bubble levels the cab of my 24' C. I have one screwed into the dash and the other over the passenger window. The bubbles tell me at a glance from the drivers seat. I can view N-S-E-W as I pull into a site or parking spot. Hardly ever use my levelers for leveling.
I only use my jacks to lift my rv when doing the tires. I lift it, then use jack-stands to the frame to support its weight.
Gjac
Milford, CT
bobndot wrote: Gjac, I'm not sure how much weight the rear axle can support.
I only use my jacks to lift my rv when doing the tires. I lift it, then use jack-stands to the frame to support its weight. Rear axels can support 7275 lbs front 4630 lbs DW is 8290 lbs. That leaves 3615 lbs of fluids and stuff which sounds good to me. Seems a lot better than the MB chassis. It sounds like fuel economy is a wash also.
bobndot
Are you going by the advertised dry weight when calculating the payload ?
If so, a trip to a scale from the dealers lot would be in order before you load it up.
Most class C’s in this size will roll down the road, loaded for s trip in 12,000lbs range.
Incl : Fluids, gear , food, people , optional rv equipment.
