RV.Net Open Roads Forum: 2022 F-150 Can Not install aftermarket brake controller!!!!!
Search only in Tow Vehicles
 > 2022 F-150 Can Not install aftermarket brake controller!!!!!
Ivylog
Blairsville, GA and WPB, FL.
Posted: 04/27/22 06:37am Link  |  Quote  |  Print  |  Notify Moderator
I had the same surprise…21 F350 and no brake controller, but I can tow a 18,000 lb trailer… just can’t stop it. Dealer wanted $200 for controller & $50 to install. Bought a $30 one on EBay and had dealer install for $50.
Your truck should have come with a pigtail to use your P3. Getting to the plug requires pulling the dash apart, not that hard once you watch a video.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
bobsallyh
Livingston, TX.
Posted: 04/27/22 10:53am Link  |  Quote  |  Print  |  Notify Moderator
This will probably be the next "subscription" service that manufactures will come up with. Pay for "towing season", then have it knocked off after trailer is parked for winter.
dcb17b
foothills of the Adirondacks
Posted: 04/27/22 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Mike134 and Ivylog you are correct that the harness is there but you can't hook anything but the OEM to it. No adapter exists and the trucks computer will not recognize it,so it won't work.Everthing for the trailer brake system goes through the computer. I have installed all my other controllers in the past but this truck is a lease so I'm not going to mess with it. I guess that is the cost of driving a shiny new truck these days. And $50 bucks to install is a smoking good price. Here in upstate NY it's 3 times that.
2022 F-150 STX 2,7 Ecoboost
2020 Wildwood FSX 179DBK
dcb17b
Posted: 04/27/22 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Bobsallyh you are probably right. I am getting "subscription notices" all the time. Whatever happened to just putting gas in it,changing the oil and treating it to a good hand wax every now and then? Man this truck is needy[emoticon]
Mike134
Elgin, IL
Posted: 04/27/22 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
You sure?
https://www.etrailer.com/bc-2022_Ford_F-150.htm
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
enblethen
Moses Lake, WA
Posted: 04/27/22 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Some rigs have the harness for the factory controller plugged into the receptacle. You should be able to unplug factory harness and plug in the Tekonsha one.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Posted: 04/27/22 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
@dcb17b, have you actually looked for a brake switch yet to tap into?
I would not have even expected an aftermarket controller to integrate to the trucks system.
Short of that option, there are wireless controllers that are plug n play. They’re $200-400 but no muss no fuss.
* This post was edited 04/29/22 09:08am by an administrator/moderator *
Adam R
ut
Posted: 04/27/22 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Prodigy that I move between three of my vehicles as needed. No problems with it working as intended and doing its job.
Posted: 04/27/22 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
That’s nice…
2017 Heartland Torque T29
mkirsch
Rochester, NY
Posted: 04/28/22 05:25am Link  |  Quote  |  Print  |  Notify Moderator
That's the point. Apparently the 2022 Ford does NOT have this.
Until someone comes up with a hack, your only choice is to pay for the factory controller.
