theoldwizard1
SE MI
Is anyone using the new Ranger as a tow vehicle ? I am a bit disappointed that the factory tow package did not upgrade either the transmission cooler or radiator.
I'm thinking of a trailer with GVW of around 5,000 lbs. Maybe even a small 5th wheel. Probably 4 passengers and very little other cargo in the truck.
Cambria, California area
Three passengers will easily take 600 pounds of payload. Add 700 pounds of tongue weight. Will your proposed Ranger handle that? A 5er at 5,000 pounds will add 1,000 pounds of payload. Rangers are good trucks but that’s too much IMO.
bgum
South Louisiana
The Ranger is considered a midsized truck. It is in the same class as a Toyota tacoma. I would not want to try what you are thinking. You would not have any fudge room.
jdc1
Rescue, Ca
The fuel millage difference between an F150 and a Ranger is negligible. More room in an F150 too.
valhalla360
No paticular place.
Why are you looking at a Ranger? Really hardly any smaller than an F150 and you can spec an F150 with much better payload and towing options.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
APT
SE Michigan
Do you already have the Ranger? Payload and rear axle ratings will be exceeded well under tow rating. It should be fine for about 4000 pound dry TT. I cannot think of any 5th wheel that would support a 200 pound receiver in the bed and even modest 15% pin weight.
Power from the Ecoboost should be fine.
2017 Subaru Outback 3.6R
2020 Chevrolet Bolt
MFL
Midwest
While the new Ranger is larger, more powerful, than the earlier models, I have to agree with others, the 150 being a much better choice. For price dif, gas mileage dif, comparing true tow capability, such as a TT, small FW, the Ranger has little to offer.
They are nice looking though! ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Jerry
MNRon
Tennessee
Not many 5ers can realistically be pulled with an F150-class, can't imagine any that a Ranger-class TV would work with...
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
valhalla360
No paticular place.
MNRon wrote: Not many 5ers can realistically be pulled with an F150-class, can't imagine any that a Ranger-class TV would work with...
Maybe something like the Scamp line but really 5ers don't make a lot of sense unless you go big.
You lose much of the truck bed storage to the 5er hitch. With a big 5er, that's offset by the big underbelly storage. But the really small 5ers generally don't have a lot of storage to negate the loss of the truck bed. A similar size bumper pull has as much storage and you get full use of the truck bed.
Boomerweps
Hills of PA
The Ranger is a very nice smaller truck. Much easier to park and operate in tighter spaces in town.
Tow rated at 7000# WITH NO WDH, according to Ford.
Ranger pricing isn’t that far off from an F150.
Adding the fifth wheel comments can be from a lack of research but, to me, is almost trolling ??
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
