RV.Net Open Roads Forum: Towing: New Ranger for towing
Search only in Towing
Open Roads Forum  >  Towing
 > New Ranger for towing
valhalla360
No paticular place.
Posted: 04/28/22 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Boomerweps wrote:
The Ranger is a very nice smaller truck. Much easier to park and operate in tighter spaces in town.
Have you seen them side by side? This isn't a 1980's ranger where it was drastically smaller.
The F150 (same cab/bed) is only 2" wider and just over a foot longer.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Posted: 04/28/22 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
Is anyone using the new Ranger as a tow vehicle ? I am a bit disappointed that the factory tow package did not upgrade either the transmission cooler or radiator.
I'm thinking of a trailer with GVW of around 5,000 lbs. Maybe even a small 5th wheel. Probably 4 passengers and very little other cargo in the truck.
Don't let the weight cops dissuade you oldwiz!
2017 Heartland Torque T29
Boomerweps
Hills of PA
Posted: 04/29/22 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
New trucks for a side by side comparison? Not at any local to me Ford dealer currently. Last time time I had services done on my truck the showroom was EMPTY!
Yes, they do look a lot bigger but I hadn’t seen the measurements.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
deltabravo
Spokane, WA
Posted: 05/01/22 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I... Maybe even a small 5th wheel.
I've never seen a 5th wheel that's small enough to be towed by a mid-sized truck in recent years.
JIMNLIN
Oklahoma
Posted: 05/02/22 06:16am Link  |  Quote  |  Print  |  Notify Moderator
The Ranger has a 6050 gvwr and the 2wd models have a 3500 rawr.
At 270 hp and 310 torque its better hp/torque numbers than 3/4 ton truck/small blocks I towed with in the past.
Many new F150 has 3300-3400 rawr and less rear axle payload than the Ranger.
Agree don't let the forums weight police scare you away from buying a Ranger...or any truck you want or need at this time.
Fleet Ford weight specs shows a base payload in the 1700-1800 lb range. We all know a highly optioned truck can have a bit less rear axle payload so choose the model best suits your needs.
Rangers like any 1/2 LDT with 3300-3500 rawr is better suited to pull a TT than a 5th wheel rv trailer.
https://uploads.documents.cimpress.io/v1........513235b4~110/original?tenant=vbu-digital
* This post was edited 05/02/22 07:03pm by JIMNLIN *
goducks10
There
Posted: 05/02/22 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.rvtravel.com/rv-review-scamp-19-smallest-fifth-wheel/
mkirsch
Rochester, NY
Posted: 05/03/22 09:16am Link  |  Quote  |  Print  |  Notify Moderator
They're still making those scamps?
