RV.Net Open Roads Forum: Tech Issues: Temperature sender/sensor... 7.3L
 > Temperature sender/sensor... 7.3L
groundhogy
PA
Posted: 04/28/22 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All,
I think RV'ers tend to have a diverse knowledge of things.
Now that you're buttered. lol
My temperature sender/sensor is doing odd things.
It was just replaced (and I don't wish to contact them again.).
It is either all the way hot, or all the way cold. Occasionally I've seen it in the middle.
This morning I watched it carefully, as it was in the rare middle position. Within a few minutes I saw it rise to all the way hot. Pegged.
Then during the day it will switch to all the way cold.
Anyone ever heard of this happening?
BurbMan
Indianapolis, IN
Posted: 04/28/22 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you have air in the coolant system, some coolant systems have very specific bleed procedures after you open them up to replace components.
Ahhh....feels good to be buttered!
LittleBill
Scranton, PA USA
Posted: 04/28/22 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
sounds more like the wiring is chaffed and causing issues with the sensor
groundhogy
PA
Posted: 04/29/22 12:11am Link  |  Quote  |  Print  |  Notify Moderator
Thanks BurbMan.
You are wonderful.
And very insightful.
And full of ... intelligence...
groundhogy
PA
Posted: 04/29/22 12:19am Link  |  Quote  |  Print  |  Notify Moderator
What about this theory.
Wrong part.
Same mechanical dimensions.
But more sensitive thermistor?
(Im assuming its some type of resistor inside)
groundhogy
PA
Posted: 04/29/22 12:23am Link  |  Quote  |  Print  |  Notify Moderator
Cant be chaffed wiring cuz it worked before.
But i was thinking possibly the contacts in the connector weren’t touching properly, but i am now doubting that.
I took a sewing pin and tried scratching/cleaning contacts and attempted to bend contact plates so as to touch male pins better. No difference.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 04/29/22 01:31am Link  |  Quote  |  Print  |  Notify Moderator
The only way to nail this to the sender is to put a jumper resistor between the disconnector sender plug and chassis ground.
If the gauge needle still wanders then you definetly have a gauge, or g
Harness problem.
Get on a search engine to the aficionado's web page for your vehicle. Your mission will be to ask the resistance range of your sending unit.
You need to go to radio shack and buy a resistor halfway in between the high andow resistance extremes.
Skibane
San Antonio, TX
Posted: 04/29/22 01:43am Link  |  Quote  |  Print  |  Notify Moderator
Typically, the vehicle manufacturer publishes a chart (usually in the Factory Service Manual) that shows how much resistance the sender is supposed to be producing at any particular temperature.
You look up that resistance on the chart, and then use an ohm meter to measure the actual resistance being produced by your sender.
If your measured resistance comes close to matching the resistance shown on the chart, you know that your sender is good - and that you problem is somewhere else.
Posted: 04/29/22 04:27am Link  |  Quote  |  Print  |  Notify Moderator
Second on a wire issue.. Hot/Cold one is shorted the other open.
Middle of the dial. that's when it is reading the sensor.
BurbMan
Indianapolis, IN
Posted: 04/29/22 06:09am Link  |  Quote  |  Print  |  Notify Moderator
MEXICOWANDERER wrote:
You need to go to radio shack and buy a resistor halfway in between the high and low resistance extremes.
Mex you've been south of the border for too long, no more Radio Shacks.
I'm changing my diagnosis to wiring also. Air in the system will cause the gauge to go full hot when the air pocket hits the sensor area, but does not explain the gauge going to full cold after that.
At the same time, chafed wiring is not as likely on newer vehicles....I would replace the sender and see if that fixes it, they are fairly inexpensive.
* This post was edited 04/29/22 06:29am by BurbMan *
