Ranger Smith
Wherever the rig is parked
dougrainer wrote: The OP's P/N is for a ROOF AC CONTROL BOARD. Why are people posting about their refers???????? Dino does not make AC control boards for Dometic. Doug
I posted a link where he could get one. You said they are available . . . Not sure he reads the reply's. My search came up the same as you. A control board for an AC unit.
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
Wade44
Ohio Farm Country
dougrainer wrote: Why are people posting about their refers???????? Doug
Because you have those with some technical or mechanical aptitude, and then you have those who have not a clue, that are best off to leave such things to others, but they still feel the need to post their "valuable" advice or comment which does not have snot to do with the subject?
2018 Marathon H3-45
2019 GMC Sierra Denali (Toad)
2012 Grady White 271 Canyon
Ranger Smith
Wade44 wrote: dougrainer wrote: Why are people posting about their refers???????? Doug
AGREE . . . Glad they are not working on my rig.
dougrainer
Carrolton, Texas
If you really need it, you can buy the complete system including the 5 button CCC wall tstat. About $100 more than just the control board. That said, what makes you think your control board is bad? They rarely go bad. What is the failure? Doug
https://www.ebay.com/itm/274201624127?ch........HAJ0NNFy9yw_26T_Dnp9U19s37gaAl8CEALw_wcB
dougrainer
Carrolton, Texas
This will be your board. Doug
https://www.amazon.com/Dometic-3312022-T........YY/ref=pd_lpo_1?pd_rd_i=B00NF1MVYY&psc=1
PastorCharlie
NC
RV dealer tested and said bad mother board. have one on order for over 1 year. Came new from factory with 5 button tstat. Illustrated board not like mine.
edited 05/01/22 02:19pm by PastorCharlie *
dougrainer
Carrolton, Texas
If you have a 5 button CCC, both on my links ARE your board. The first link shows the galvinized box the board is in and the 2nd shows the raw board. BOTH are the same. You still have not stated what your failure was. As I stated, the boards rarely fail and is usually a communication cable problem NOT the Board. I have repaired lots of 5 button CCC systems where other service centers and the customer have replaced the board and when the new board did not fix the problem they came to me. Doug
PastorCharlie
NC
The unit will not run. The coach stays plugged into 50 AMP service all time when not in use and both units are set to keep it comfortable inside. During my absence the back unit stopped and does not now work. The front one does ok and cools and heats the whole house.
I will make it a point to check the unit when I have the time.
dougrainer
Carrolton, Texas
What does the display state on the wall tstat? Doug
PastorCharlie
NC
dougrainer wrote: What does the display state on the wall tstat? Doug
FAN: Auto
SET POINT: 72* F
MODE: Cool or Heat Pump if set to heat pump. Depends upon what mode is set.
