RV.Net Open Roads Forum: Tech Issues: stuck dump valve
 > stuck dump valve
jjrbus
FT Myers FL
Posted: 05/03/22 04:38am Link  |  Quote  |  Print  |  Notify Moderator
A long time ago in a land far away the wizened ancient ones entrusted me with their knowledge of keeping valves operating.
Google something like Zerk fitting in rv holding tank valve, bit of grease every now and then and no issues. Or search this forum.
opnspaces
San Diego Ca
Posted: 05/03/22 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Does the handle possibly have a threaded keeper end to help keep it closed? Are you able to turn the cable or handle with it disconnected from the valve?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
msmith1.wa
Tacoma, WA
Posted: 05/03/22 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
I replaceded the braided cables on mine with these last year after one broke.
These are a thin single piece similar to an electritian's fish tape.
cable
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
walker111
se calgary
Posted: 05/10/22 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
cable
I had to operate on the underbelly on my trailer also a few years ago ( not medically certified in my province but oh well....) due to similar issue with the handle. Was a pain to cut section of chloroplast out and get to the issue. I replaced with the one shown above also.
travelRVforever
Michigan
Posted: 08/10/22 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
YEP I said BYE, BYE to remote valves and relocated to an easy location with standard Valterra "T" handle valves.
Great place to buy Valterra parts if you are looking for anything they sell is valterraparts.com, they have everything!
shum02
Burlington ON CDA
Posted: 08/10/22 11:29am Link  |  Quote  |  Print  |  Notify Moderator
relaxin wrote:
located the dump valve and cut open the underbelly, took off the calbe and the valve moves freely, so cable is seized, strange for a 3 year old unit hardly used. held the handle end lightly in a vise and gave it a good dose of penetrating oil a few times over several hours, let it sit overnight, and still stuck,,, FN@#!#%& !!! so ordered a new one, unfortunately only comes with the valve at $180 (cdn)
Has anyone seen if any aftermarket place makes them in stainless steel?
I ordered just the cable and T-handle off Amazon Canada.
Valterra Waste Valve Cable
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
Cummins12V98
on the road
Posted: 08/10/22 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
NO WAY would I own another cable dump valve. One year and the Black was unusable. 6 years on the standard "T" valves and they operate like new.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Skibane
San Antonio, TX
Posted: 08/11/22 10:35am Link  |  Quote  |  Print  |  Notify Moderator
bucky wrote:
If the tank is empty and the RV is level the valve will be the lowest point and all of the vegetable oil will sit right there and sometimes do it's magic. Any water in the tank and the oil will float on top accomplishing nothing.
Yep, that's the problem with most oils - Since they're lighter than water, they float away after they're submerged.
Vaseline is also slightly lighter than water, but has better "stickyness" than most oils.
Heated to 140 degrees F, it pours like water.
StirCrazy
Kamloops, BC, Canada
Posted: 08/12/22 06:43am Link  |  Quote  |  Print  |  Notify Moderator
what was the problem with yours, I have two and 6 years later they work perfectly.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
campermama
Here and There
Posted: 08/12/22 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I had this problem...valve was stuck slightly open, I used a camera to see what was going on. I cut the cable and relocated the handle right by the drain pipe so the cable is now shorter and straight, it was the cable that was the problem not the valve.
I also drilled a hole in the valve (another thread) so I can spray some lube in there. Oh and yeah had to cut bottom open to access. I got the schematics from Jayco so I knew exactly where to cut [emoticon]
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
 > stuck dump valve
