RV.Net Open Roads Forum: Tow Vehicles: Cummins 6.7L Gasoline Engine in a Ram?
Search only in Tow Vehicles
 > Cummins 6.7L Gasoline Engine in a Ram?
ShinerBock
LVTX
Posted: 04/29/22 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Haven't been on this forum in a while so I am not sure if this has been discussed in the past few months.
Back In February, Cummins unveiled their new fuel-agnostic strategy meaning that various engines in their line-up can be spec'd for different fuel types like propane, natural gas, hydrogen, and yes even gasoline. To clarify, that doesn't mean that one engine can run on all of these fuel sources, but rather you can have them spec'd to run on one of these fuels only and not just diesel.
These engines will share 80% of their parts. From the head down these engines will be mostly the same as the current Cummins diesel. From the head up you will have different parts to for the various fuel types along with different fuel and air delivery systems. So essentially you will have the same reliable diesel engine components, but in gasoline form.
They said that the B6.7L will be the first to be offered with its fuel-agnostic strategy in 2024. Medium duty customers will be able to spec the B6.7L to run on gasoline. I am not sure what plans Ram has for the 6.4L, but I would love to see a gasoline powered Cummins 6.7L turbo in a Ram HD. Not sure how they will handle the heat associated with gasoline turbo engines.
What do you think?
Cummins unveils fuel-agnostic internal combustion engine strategy
Cummins 6.7-liter gas engine part of new fuel agnostic strategy
* This post was last edited 04/29/22 08:35am by ShinerBock *   View edit history
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
rjstractor
Maple Valley, WA
Posted: 04/29/22 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Sounds really interesting! It's early in the morning, but Ima gonna go pop up some popcorn....
Cummins12V98
on the road
Posted: 04/29/22 09:14am Link  |  Quote  |  Print  |  Notify Moderator
My question who would buy such an expensive Gas Engine???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ShinerBock
LVTX
Posted: 04/29/22 09:38am Link  |  Quote  |  Print  |  Notify Moderator
With today's prices, I am not surprised anymore on what people will pay for stuff. Many will lay down $11k to go from a base trim package to a premium without batting an eye.
Although I don't think this would be nearly as expensive as the Cummins diesel. You would not need a lot of the emissions equipment which would reduce a lot of cost and weight. You would also not need iron heads, a VG turbo, as large of an EGR and fuels system. So there could be a lot of cost and weight savings in a gas version.
larry barnhart
wenatchee. wa usa
Posted: 04/29/22 10:27am Link  |  Quote  |  Print  |  Notify Moderator
good to have you back shiner. chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
bucky
Raleigh metro
Posted: 04/30/22 04:06am Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of turbo gassers out there. They do tend to be on the small side but the drag guys are building dual turbo big block hot rods also.
I think it's good that Cummmins is thinking ahead to the future. We'll see what fruit that tree bears.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
thomas201
Eastern Panhandle WV
Posted: 04/30/22 05:10am Link  |  Quote  |  Print  |  Notify Moderator
I bought a herd of Kubota diesel engines converted to casing head gas, to power pump jacks on oil wells. Honda gasoline engines just self destructed. They did not have enough cooling in the heads. They were designed with the evaporation of gasoline in mind for some cooling. If your ran them at max horsepower, they just could not cut it.
So, they might have a market, but I don't think it would be real big. Interesting though, assuming you get Cummins support. Would truck owners buy a gas engine, at diesel engine prices???
FishOnOne
The Great State of Texas
Posted: 04/30/22 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Just another example for the future of diesel.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
FishOnOne
Posted: 04/30/22 06:52am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like there's a lot of common parts on these engine configurations so there was engineering cost savings, tooling savings, and I suspect all these engine configurations will be produced on the same assembly line as the diesel engine so that should equate to more savings.
So overall less investment and operations costs to bring these engine configurations to the market should mean a less expensive engine.
* This post was edited 04/30/22 09:50am by FishOnOne *
Bionic Man
Colorado
Posted: 04/30/22 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Wouldn’t the fuel economy of a 6.7 turbo gas engine make almost unaffordable?
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
