RV.Net Open Roads Forum: Fifth-Wheels: Bedroom slide bind
 > Bedroom slide bind
routemaster
Deming
Posted: 04/30/22 10:42am Link  |  Quote  |  Print  |  Notify Moderator
I have an issue with our bed slide with the Bal-Accu system installed. Problem is that the top left and bottom right corners are in a bind and have destroyed the wipes. On inspection, I have found that the sill is running down towards the front the king studs are plumb. So, I am thinking to take the box out of the bind I would have to shim up the rollers by at least 1/4"+ on the first one then a 1/8" on the second one, which I don't think is likely to do no space to get at the screws or I have some three-roller plates which I could shim too different thicknesses to create the run on the sill. One other thing that came to mind was to buy a J-36 roller and fix the outside wall. Thoughts, please.
Make sense?
2017 Landmark Arlington 365
2015 Silverado LTZ 3500 c/c LWB.
dougrainer
Carrolton, Texas
Posted: 04/30/22 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I have worked on and FIXED Dozens of Accu Slide systems. And YES, I have no idea what you are talking about[emoticon] Download this link and watch the various video's and see if that does not help you. Doug
https://balrvproducts.com/products/oem/accuslide/index.shtml
routemaster
Deming
Posted: 04/30/22 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, Sir.
Let's hope these pictures tell my story. you will I tried to jam in the new seals with no room for the flip in one picture? I had thought that the bottom sill weld was broken but I think it was welded in wrong.
Den.
routemaster
Deming
Posted: 04/30/22 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
phillyg
SWFL
Posted: 05/01/22 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I'm struggling to understand the problem, even with the photos. Since the top left and bottom right is binding, the first thing I'd check for is the slide box racked.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
routemaster
Deming
Posted: 05/01/22 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Not Shure what is meant by racked, I thought that the box was a parallelogram but, on a check, it is not the box is just laying down to the left outside view.
Wade44
Ohio Farm Country
Posted: 05/01/22 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately attention to detail and the words plumb, level, straight, or square do not exist in the vocabulary of the mass producing midwest RV manufacturers. They have a hard time getting so much as a decal straight. They also could care less what happens as soon as the sale is made.
2018 Marathon H3-45
2019 GMC Sierra Denali (Toad)
2012 Grady White 271 Canyon
routemaster
Deming
Posted: 05/01/22 11:43am Link  |  Quote  |  Print  |  Notify Moderator
I still have a bent frame to deal with still when I can make the trip to the AZ fabricators.
routemaster
Deming
Posted: 05/01/22 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
I was told that the gap on either side of the box outside wall should be 5/8" and I haven't got that.
nickthehunter
Southgate, MI
Posted: 05/09/22 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly the bent frame is causing your slide problem?
