routemaster
Deming
So, as I don't destroy the new set of wipes, I have bought three-roller plates to fix under the floor for rollers to run on, then shim them up to create the run on the sill to take out the bind until I can get the frame straightened and remove the shims.
Thoughts.
2017 Landmark Arlington 365
2015 Silverado LTZ 3500 c/c LWB.
routemaster
Deming
Hey Doug.
I bought three lengths of aluminum for the roller plates and I was going to shim the center one up by a 1/8" then on the other one by a 1/4"so as to create a run on the sill this was just to take the corners away from the studs, so as not to shear the wipes. The rough out does appear to be out of square by at least 7/16"/ 1/2".Jacking up the low end does take the floor away from the internal wipe don't like that idea.
Your thoughts please being you worked on these Accu-slides.
Den.
